AUDIOPHONICS ELECAUDIO Redline OCC Stereo Cinch RCA Interconnect Cable 1.2m
Reference : 11893
119,00 €tax incl.
99,17 € tax excl.
Thanks to its expertise in custom-made audio / video cable, ELECAUDIO has designed the sc-221occ modulation cable SC-221OCC using the best materials available to meet your expectations and needs.
elecaudio SC-221OCC
PC-OCC copper conductors of a large section of 0.71mm² each and the insulation PTFE, which ensures high mechanical strength, are a guarantee of a pure and detailed reproduction for your HiFi system.
The Double shielding with 100% overlap ensures protection against interference frequencies: A first shielding made from copper finely woven, then a second made of aluminum strip
The whole is protected by a thick PVC sheath.
The construction uses cotton filling and paper sheet in order to hold the 2 conductors together. They also ensure a good flexibility to the cable.
This RCA modulation cable has been assembled by us in the workshops of Audiophonics.fr by a qualified technician.
The choice of materials, welding,the assembly method has been scrupulously studied to the smallest details to offer you a high-end cable at a competitive price.
Characteristics of the ELECAUDIO SC-221OCC cable:
  • Copper conductors OCC composed of 77 strands of 0.12mm PC-OCC (2x 0.88mm²)
  • Insulation of PTFE conductors
  • Cotton padding
  • PTFE insulation + PVC sheath
  • Aluminum foil
  • Copper braid shielding
  • Paper coating
  • External Diameter: 8.6mm
Characteristics of the ELECAUDIO RC90-REDC connectors:
  • Red Copper Conductors: 99.9% pure copper
  • Central Pin and Red Copper 24k Gold Plate Pine
  • White connector and red connector
  • ABS base
  • Housing Black anodized aluminum
  • Silkscreen: Logo Elecaudio
  • Acceptable cable diameter (to be welded): Ø 9mm
  • Overall length: 44.5mm
  • Total diameter: 12.5mm
  • Exclusive design
  • Weight: 6g / unit
Length (m)1.2
ShieldingYes
