SOMMERCABLE SINUS CONTROL Gold Plated RCA-RCA Modulation Cable 1m
Reference : 2379
85,01 €tax incl.
70,84 € tax excl.
The SINUS CONTROL cable is almost a cult status among hi-fi enthusiasts and hi-fi enthusiasts alike, because at a ridiculously low price, you get a cable that stands up to all competing products high-tech much more expensive.
Already installed on thousands of systems, it is highly appreciated thanks to its effective shielding: a copper tubular braid and an aluminized polyester sheet ensure perfect protection against BF and HF interference.
Theof the generous insulation in compressed PE Skin, it shows a very low capacity value and a minimum loss of power over long distances, characteristics uncommon in hi-fi systems.
The cable is provided with a servo-control conductor, which can be used, for example, for controlling a CD player or other apparatus, or possibly as a ground conductor.
The HICON HI-CM12 connectors are gold-plated and insulated Teflon.
USES:
Phono, instrument and Cinch cable for medium to high demand
Connections for high-performance hi-fi and hi-fi systems
ADVANTAGES :
Bass reproduction faithful and intensive
Double protection with 100% overlap
Integrated control system (remote control)
Gold-plated and Teflon insulated connectors
Length (m)1.0
Section (mm²)N/A
ConnectorRCA
