TRIANGLE RED Phono RCA Cable with Ground Wire OFC Copper 3m (pair)
This Red RCA cable from Triangle is made of 99.9% pure OFC copper for optimal signal conductivity and faithful sound reproduction. It is designed to connect audio sources to audio amplifiers or active speakers.
Reference : 21785
54,90 €tax incl.
45,75 € tax excl.
Triangle Red Subwoofer Cable RCA OFC Copper with Ground Wire 3m (The pair)
Photo of the RCA cable
This Red RCA cable from Triangle is made of 99.9% pure OFC copper for optimal signal conductivity and faithful sound reproduction. It is designed to connect audio sources to audio amplifiers or active speakers. To this end, the cable is equipped with gold-plated RCA connectors, featuring two male RCA connectors on each end. For turntables, ground wires are also included to ensure an optimal, noise-free connection to your amplifier.
To ensure the conductor is protected, it is insulated with several layers of PVC, an aluminum foil, and a braided textile sheath, which guarantee signal integrity and stability. The connectors are marked with arrows to facilitate installation.
Product typePhono RCA interconnect cable
Length3m
ConnectorsRCA male
Cable conductor material99.99% pure OFC copper
Connector platingGold
ShieldingYes
SheathBraided
ColorBlack and Red
Weight336g
PackageSold in pairs
Length (m)3.0
ShieldingYes
Section (mm²)N/A
ConnectorRCA
TRIANGLE RED Phono Cable RCA with Ground Wire OFC Copper 3m (Pair)
This Red RCA cable from Triangle is made of 99.9% pure OFC copper for optimal signal conductivity and faithful sound reproduction. It is designed...
