Tolerance (%)
1 % - 20 %
Capacitor capacitance (µF)
Capacitor format
Capacitor type
Rated voltage (V)
Capacitors
Tomasz C.
Powerful combination
The Wiim Ultra Streamer has all the bells and whistles in terms of connecting TV's, Record Player and all the streaming...
Jean Jacques R.
gaine large
j'ai du re-commander cette dimension pour mettre 2x cables de diam 7mm, je pensais que la gaine 7-14 pouvait faire 14mm de...
Jean-François G.
Nouvelle TV, nouvelle connectique: pas de sortie audio analogique ni de prise casque. L’utilisation de ce petit appareil a...
Capacitors
  • Polarized capacitors
  • Non-polarized capacitors
  • Capacitors accessories
  • Ref : 12089
    In Stock
    Jantzen Audio Alumen Z-Cap capacitors are based on the Silver Gold Z-Cap series with a more neutral and musical tonal presence. This Aluminium Polypropylene series provides a more balanced presentation without the excessive brightness of other high-end capacitors exaggerating the upper parts of the audio spectrum.
    69,60 € 58,00 €Ex.
    In Stock
  • Ref : 12090
    In Stock
    77,60 € 64,67 €Ex.
    In Stock
  • Ref : 12091
    In Stock
    88,60 € 73,83 €Ex.
    In Stock
  • Ref : 12092
    In Stock
    98,30 € 81,92 €Ex.
    In Stock
  • Ref : 18646
    In Stock
    Capacitors JANTZEN AUDIO Alumen Z-CAP are based on the Gold Silver Z-CAP series and benefit from a more ambitious assembly in terms of tonal neutrality.
    33,20 € 27,67 €Ex.
    In Stock
  • 116,80 € 97,33 €Ex.
    In Stock
  • Ref : 19437
    In Stock
    Jantzen Audio's Amber Z-Cap capacitors are made from pure copper foil of the highest quality. They have been specially designed for the tweeter section of crossover filters for passive HiFi loudspeakers. They are also ideal for use in the midrange. Amber Z-Caps are designed to deliver a more neutral sound reproduction, with an excellent balance between...
    51,00 € 42,50 €Ex.
    In Stock
  • Ref : 19440
    66,20 € 55,17 €Ex.
    In Stock
  • Ref : 19441
    92,80 € 77,33 €Ex.
    In Stock
  • Ref : 19442
    113,50 € 94,58 €Ex.
    In Stock
  • Ref : 19443
    134,70 € 112,25 €Ex.
    In Stock
  • Ref : 19444
    160,80 € 134,00 €Ex.
    In Stock
  • Ref : 19445
    188,30 € 156,92 €Ex.
    In Stock
  • Ref : 19446
    218,40 € 182,00 €Ex.
    In Stock
  • Ref : 19447
    264,30 € 220,25 €Ex.
    In Stock
  • Ref : 19448
    321,30 € 267,75 €Ex.
    In Stock
  • Ref : 18718
    In Stock
    Jantzen Audio's Compact MKT capacitors are made from the highest quality metallized polyester film available. Jantzen Audio has succeeded in making these capacitors more compact and giving them better sonic properties than standard film capacitors. With a nominal voltage of 160V DC, these capacitors are also more versatile than electrolytic capacitors.
    1,00 € 0,83 €Ex.
    In Stock
  • Ref : 18719
    In Stock
    1,30 € 1,08 €Ex.
    In Stock
  • Ref : 18720
    1,50 € 1,25 €Ex.
    In Stock
  • Ref : 18721
    In Stock
    1,60 € 1,33 €Ex.
    In Stock
  • Ref : 18722
    In Stock
    1,70 € 1,42 €Ex.
    In Stock
  • Ref : 18723
    In Stock
    1,90 € 1,58 €Ex.
    In Stock
  • Ref : 18724
    In Stock
    2,20 € 1,83 €Ex.
    In Stock
  • Ref : 18725
    In Stock
    2,40 € 2,00 €Ex.
    In Stock
  • Ref : 18726
    In Stock
    2,70 € 2,25 €Ex.
    In Stock
  • Ref : 18727
    3,20 € 2,67 €Ex.
    In Stock
  • Ref : 18728
    In Stock
    3,60 € 3,00 €Ex.
    In Stock
  • Ref : 18729
    In Stock
    4,60 € 3,83 €Ex.
    In Stock
  • Ref : 18730
    In Stock
    5,30 € 4,42 €Ex.
    In Stock
  • Ref : 18731
    In Stock
    6,40 € 5,33 €Ex.
    In Stock
  • Ref : 18732
    In Stock
    8,60 € 7,17 €Ex.
    In Stock
  • Ref : 18733
    In Stock
    12,90 € 10,75 €Ex.
    In Stock
  • Ref : 18734
    In Stock
    17,10 € 14,25 €Ex.
    In Stock
  • Ref : 18735
    In Stock
    20,90 € 17,42 €Ex.
    In Stock
  • Ref : 18736
    In Stock
    25,70 € 21,42 €Ex.
    In Stock
  • Ref : 18737
    28,90 € 24,08 €Ex.
    In Stock
  • Ref : 18738
    In Stock
    35,40 € 29,50 €Ex.
    In Stock
  • Ref : 19980
    In Stock
    Jantzen Audio Cross Cap capacitors offer a high level of performance and quality at a very reasonable price. This is a versatile model, using metallized polypropylene foil.
    1,10 € 0,92 €Ex.
    In Stock
  • Ref : 19995
    1,10 € 0,92 €Ex.
    In Stock
  • Ref : 19996
    In Stock
    1,40 € 1,17 €Ex.
    In Stock
