Tolerance (%)
1 % - 20 %
Capacitor capacitance (µF)
Capacitor format
Capacitor type
Rated voltage (V)
Capacitors
Dominique R.
Top !
Fabien F.
conforme à la documentation, avec un bon son même à faible volume. Je l’ai testé avec des large bandes Supravox 135lb...
Eric A.
Capacitors
  • Polarized capacitors
  • Non-polarized capacitors
  • Capacitors accessories
  • Ref : 11772
    In Stock
    Jantzen Audio Cross Caps MKP 400V are considered the best value for money for the design of passive crossovers for loudspeakers. Made in Europe, this new competitor of the German, French and English references enjoys a very good design quality. They are ideal for parallel RL and RLC "plug" correction in parallel circuit, instead of low quality...
    7,50 € 6,25 €Ex.
    In Stock
  • Ref : 11760
    In Stock
    1,20 € 1,00 €Ex.
    In Stock
  • Ref : 11763
    In Stock
    2,40 € 2,00 €Ex.
    In Stock
  • Ref : 18021
    2,60 € 2,17 €Ex.
    In Stock
  • Ref : 18022
    In Stock
    2,80 € 2,33 €Ex.
    In Stock
  • Ref : 13740
    In Stock
    Jantzen Audio Cross Cap MKP 400V capacitors are considered to be the best value for money for the design of passive filters for loudspeakers. Of European manufacture, this new competitor to the German, French and English references enjoys a very high quality of design.
    10,90 € 9,08 €Ex.
    In Stock
  • Ref : 11773
    In Stock
    10,90 € 9,08 €Ex.
    In Stock
  • Ref : 11764
    In Stock
    3,20 € 2,67 €Ex.
    In Stock
  • Ref : 11765
    In Stock
    3,50 € 2,92 €Ex.
    In Stock
  • Ref : 11774
    In Stock
    12,90 € 10,75 €Ex.
    In Stock
  • Ref : 11775
    In Stock
    13,90 € 11,58 €Ex.
    In Stock
  • Ref : 15563
    In Stock
    15,90 € 13,25 €Ex.
    In Stock
  • Ref : 11776
    In Stock
    14,90 € 12,42 €Ex.
    In Stock
  • Ref : 11766
    In Stock
    4,50 € 3,75 €Ex.
    In Stock
  • Ref : 11777
    In Stock
    19,90 € 16,58 €Ex.
    In Stock
  • Ref : 11767
    In Stock
    3,20 € 2,67 €Ex.
    In Stock
  • Ref : 11778
    In Stock
    18,50 € 15,42 €Ex.
    In Stock
  • Ref : 11768
    In Stock
    3,50 € 2,92 €Ex.
    In Stock
  • Ref : 11779
    In Stock
    20,50 € 17,08 €Ex.
    In Stock
  • Ref : 11769
    In Stock
    5,50 € 4,58 €Ex.
    In Stock
  • Ref : 11780
    In Stock
    29,90 € 24,92 €Ex.
    In Stock
  • Ref : 15459
    Jantzen Audio EleCap electrolytic capacitors are non-polarized aluminum capacitors using etched or "raw" foil. With a tolerance of ±5%, they are more accurate than most other standard electrolytic capacitors.
    1,00 € 0,83 €Ex.
    In Stock
  • Ref : 15480
    In Stock
    2,80 € 2,33 €Ex.
    In Stock
  • Ref : 15468
    In Stock
    1,20 € 1,00 €Ex.
    In Stock
  • Ref : 15481
    In Stock
    4,20 € 3,50 €Ex.
    In Stock
  • Ref : 15469
    1,80 € 1,50 €Ex.
    In Stock
  • Ref : 15482
    In Stock
    3,40 € 2,83 €Ex.
    In Stock
  • Ref : 15470
    In Stock
    1,20 € 1,00 €Ex.
    In Stock
  • Ref : 15471
    In Stock
    1,30 € 1,08 €Ex.
    In Stock
  • Ref : 15458
    In Stock
    1,00 € 0,83 €Ex.
    In Stock
  • Ref : 15460
    In Stock
    1,00 € 0,83 €Ex.
    In Stock
  • Ref : 15461
    1,10 € 0,92 €Ex.
    In Stock
  • Ref : 15483
    In Stock
    5,50 € 4,58 €Ex.
    In Stock
  • Ref : 15472
    In Stock
    1,30 € 1,08 €Ex.
    In Stock
  • Ref : 15484
    In Stock
    5,50 € 4,58 €Ex.
    In Stock
  • Ref : 15473
    In Stock
    1,60 € 1,33 €Ex.
    In Stock
  • Ref : 15462
    In Stock
    1,10 € 0,92 €Ex.
    In Stock
  • Ref : 15463
    In Stock
    1,10 € 0,92 €Ex.
    In Stock
  • Ref : 15485
    In Stock
    8,90 € 7,42 €Ex.
    In Stock
  • Ref : 15486
    In Stock
    8,90 € 7,42 €Ex.
    In Stock
