The FiiO Snowsky Beatbox is a portable CD player with a built-in stereo speaker, designed to combine disc playback and audio playback in a single device. Its architecture combines two mid-high speakers, a dedicated woofer and a hardware crossover to distribute frequencies and support bass reproduction.
Intended for standalone everyday listening, it can also play music via Bluetooth LDAC, from a USB flash drive or from a source connected via AUX, and features an FM radio. Its removable battery and 3.5mm jack headphone output extend the listening options, while CD ripping to WAV files makes it easy to store them on USB media.
The FiiO Snowsky Beatbox combines a CD player, a stereo speaker and several playback sources in a single device. Its acoustic architecture combines two mid-high speakers, a dedicated woofer and a hardware crossover to distribute frequencies between the drivers and deliver a wide stereo soundstage with solid bass.
The symmetrical separation of the left and right channels contributes to the definition of the stereo image, while the hardware crossover distributes the signal between the speakers to balance bass, midrange and treble. The independent bass chamber, combined with a bass-reflex port, promotes deep and responsive low-frequency reproduction. Designed to ensure stable playback, the CD mechanism uses a steel ball bearing and spring system to support disc loading and ejection.
The built-in speakers allow stereo listening without additional equipment, while the 3.5mm jack headphone output provides private listening. The magnetic rear panel makes it easy to place the Beatbox on a compatible metal surface, such as a refrigerator or a suitable stand.
In addition to CDs, the Beatbox features an LDAC-compatible Bluetooth receiver, an FM radio, an AUX input and file playback from a USB flash drive. The latter supports MP3, WMA, WAV and FLAC formats up to 48kHz. The player can also rip audio CDs to lossless WAV format directly to a FAT32 USB device; FiiO recommends a USB-C flash drive with a maximum capacity of 32GB.
The Beatbox runs on a removable 18650 battery, not included, featuring a protection circuit, which can be recharged or replaced. Rated battery life varies depending on the source and listening mode: approximately 8.5 hours on CD with headphones and 8 hours on the speakers, up to 20 hours in Bluetooth with headphones and 15 hours on the speakers. An infrared remote control complements the device, providing easy remote access to its main functions.
Technical specifications
| Specifications | |
| Product type | CD player |
| Inputs | 1x Jack 3.5mm 1x USB-C CD Bluetooth FM |
| Outputs | 1x Jack 3.5mm headphone output Built-in speakers |
| Bluetooth chip | BT8961 |
| Supported Bluetooth codecs | SBC / LDAC |
| Headphone output power | 1.25mW+1.25mW @ 16Ω THD<1% 1mW+1mW @ 32Ω THD<1% |
| Speaker output power in CD mode | Mid/high speaker: 1200mW+1200mW @ 4Ω THD<1% Bass speaker: 1050mW+1050mW @ 4Ω THD<1% |
| Speaker output power in USB / FM mode | Mid/high speaker: 2000mW+2000mW @ 4Ω THD<1% Bass speaker: 1900mW+1900mW @ 4Ω THD<1% |
| Output impedance | <1Ω |
| THD+N | <0.02% |
| SNR | ≥90dB |
| Noise floor | <5.5µV |
| Battery life in CD mode | Headphone output: 8.5h Speaker: 8h |
| Battery life in Bluetooth mode | Headphone output: 20h Speaker: 15h |
| General | |
| Supply voltage | 5V DC / 3A |
| Dimensions | 190 x 190 x 36.5mm |
| Weight | 615g |
| Color | Black |
| Package | 1x FiiO Snowsky Beatbox 1x Remote control 1x USB-A to USB-C cable |
