FOSI AUDIO DISC NANO CD Player Black
New
The Fosi Audio DISC Nano is a compact CD player, 102 mm wide, designed to bring disc playback to spaces where a traditional unit would be difficult to install. Its CS43198 DAC handles audio signal decoding, while the Bluetooth link lets you listen to CDs with a compatible headphone or speaker.
Reference : 22636
109,00 €tax incl.
90,83 € tax excl.
Fosi Audio Disc Nano Bluetooth Battery-Powered CD Player Black
Fosi Audio DISC Nano: Front view
The Fosi Audio DISC Nano is a compact CD player, 102mm wide, designed to bring disc playback to spaces where a traditional unit would be difficult to install. Its CS43198 DAC handles audio signal decoding, while the Bluetooth link lets you listen to CDs with a compatible headphone or speaker.
Intended for offices, kitchens and small listening spaces, it combines magnetic mounting and an ESP anti-shock system to ease installation and limit playback interruptions when the unit is moved. This design keeps a CD collection accessible while adapting to different listening setups.
Fosi Audio DISC Nano: Compact CD player
The Fosi Audio DISC Nano is a 102mm wide CD player, designed to provide disc playback without taking up the space of a traditional player. Its small footprint makes it easy to install on a desk, in the kitchen or in a music corner, while the magnetic mounting allows it to be placed directly on a metal surface, such as a refrigerator door. It thus fits into different living spaces while keeping CDs within reach.
Fosi Audio DISC Nano: Wireless and anti-shock playback
Bluetooth transmission lets you listen to discs with a compatible headphone or speaker, without adding audio cabling between the player and the listening system. To support this placement freedom, the ESP electronic anti-shock system helps reduce playback interruptions caused by movement. This combination makes the DISC Nano suitable for listening in spaces where the player may be moved or installed on a high-traffic surface.
Fosi Audio DISC Nano: CS43198 DAC
The player features a CS43198 DAC, responsible for decoding the CD's audio data. This conversion is part of a compact unit that combines physical playback and wireless listening, letting you enjoy a disc collection with a Bluetooth headphone or speaker, even when available space is limited.
Technical specifications
Product typeCD player
Outputs1x Jack 3.5mm single-ended
1x Jack 4.4mm balanced
Bluetooth
DAC chipCS43198
SNR≥100dB
Output power86mW+86mW @32Ω, THD+N <1%
Compatible headphone impedance16–300Ω
Battery800mAh
Supply voltage5V/1A
Dimensions102 × 102 × 29mm
Weight210g
Package1x Fosi Audio DISC Nano
1x USB-A to USB-C cable
FOSI AUDIO DISC NANO Bluetooth Battery Powered CD Player Black
The Fosi Audio DISC Nano is a compact CD player, 102 mm wide, designed to bring disc playback to spaces where a traditional unit would be difficult...
