THINKYA DVP560 Battery-Powered CD Player
The Thinkya DVP‑560 is a compact CD player with integrated amplification, designed to ensure stable disc playback while extending listening possibilities to external and wireless sources. It leverages optimized read mechanics with anti-jitter system, coupled with Toslink optical output and bidirectional Bluetooth 5.1 transmission, thereby guaranteeing controlled signal circulation according to the selected usage mode.
Reference : 22244
75,90 €tax incl.
63,25 € tax excl.
Shipping date: 17-11-2026.
Thinkya DVP‑560 Battery-Powered CD Player Bluetooth 5.1
Thinkya DVP‑560 : Front view
Intended for autonomous use or as a complement to a Hi-Fi installation, it combines CD playback, USB playback and restitution via integrated speakers, enabling immediate exploitation without additional equipment. This approach enables it to serve as a versatile audio source, while maintaining coherent restitution suited equally to near-field listening or integration into an existing system.
Thinkya DVP‑560: Versatile connectivity
The Thinkya DVP‑560 integrates connectivity structured around a Toslink optical output, enabling clean digital signal routing to an external converter, while the 3.5 mm jack headphone output authorizes direct listening with local level control. This architecture extends to an AUX input facilitating analogue source injection, while USB playback ensures compatibility with MP3, WAV and FLAC formats, thereby extending usage beyond CD. Additionally, bidirectional Bluetooth 5.1 enables both reception and transmission of signal, authorizing flexible integration into a wired or wireless environment.
Thinkya DVP‑560 : Bluetooth connectivity
Thinkya DVP‑560 : Read head
Thinkya DVP‑560: Optimized read mechanism
The read head relies on a mechanical stabilization system integrating an anti-jitter function, limiting disc tracking variations to reduce read errors. This approach extends to anti-reflection treatment that improves optical beam precision, thereby enabling consistent restitution even in the presence of discs exhibiting micro-irregularities.
Thinkya DVP‑560: Integrated sound restitution
The DVP‑560 embeds two 50 mm speakers, whose combination structures coherent stereo reproduction in a compact format. This configuration delivers 3 + 3 W power at a distortion rate below 0.1%, resulting in stable near-field listening, suited to autonomous use without external amplification.
Thinkya DVP‑560 : Speaker
Thinkya DVP‑560 : 2600 mAh battery
Thinkya DVP‑560: 2600 mAh battery
Integration of a 2600 mAh battery enables runtime between 6 and 8 hours of continuous playback, authorizing extended use without systematic recourse to AC power. This autonomy translates to usage flexibility, whether in a mobile domestic context or while traveling, while maintaining stable operation over time.
Product typeCD player
Inputs1x 3.5mm jack
1x USB-A
CD
Bluetooth
Outputs1x Toslink optical
1x 3.5mm jack headphone
Bluetooth
Bluetooth version5.1
Supported formatsCD / CD-DA / CD-R / CD-RW / MP3 / WAV / WMA / FLAC
Signal-to-noise ratio (SNR)≥80dB
Frequency response20Hz-20kHz
Output power2x 3W
Bit rate320Kbps
Chassis materialWood
Battery2600mAh
Runtime6~8h
Charging time3h
Charging portUSB-C
Supply voltage5V 2A
Weight670g
Dimensions178 x 158 x 48.5mm
ColorWood
Package1x Thinkya DVP‑560
1x Remote control
1x 3.5mm jack to 3.5mm jack cable
1x USB-A to USB-C cable
THINKYA DVP560 Battery-Powered CD Player Bluetooth 5.1
The Thinkya DVP‑560 is a compact CD player with integrated amplification, designed to ensure stable disc playback while extending listening...
