GRESENG MH-D30 Tubes CD Player
The Greseng MH-D30 is a tube CD player designed to handle the playback and conversion of digital sources within a hi-fi system. It is based on a hybrid architecture combining an SPHE8104 DAC with a Beijing 6S6 tube output stage, in order to influence the final sound reproduction without altering the signal structure, resulting in a more nuanced sound whilst maintaining a low level of distortion.
Reference : 21986
499,00 €tax incl.
415,83 € tax excl.
Greseng MH-D30 Tubes CD player DTS HD Bluetooth 5.2
Miniature of the Greseng MH-D30
Designed for versatile integration into home audio systems, it combines balanced and unbalanced analogue outputs with digital outputs, allowing the audio signal to be routed to an amplifier, an external DAC or headphones. This approach is further enhanced by the addition of USB and Bluetooth 5.2 inputs, enabling the playback of digital files and wireless streaming, whilst its aluminium chassis stabilises the playback mechanism and ensures consistent performance across a variety of Hi-Fi setups.
Greseng MH-D30: Connectivity and audio output
The Greseng MH-D30 offers a very wide range of connection options. It features XLR and RCA outputs for analogue connections, as well as Toslink optical and coaxial outputs for digital connections. But that’s not all, this CD player also features a 3.5mm headphone jack on the front panel.
In terms of inputs, the player combines its CD mechanism with a USB-A port capable of playing audio files from a USB stick with a capacity of up to 128GB. Finally, the MH-D30 is also equipped with Bluetooth 5.2 connectivity for wireless use with a smartphone.
Photo of the Greseng MH-D30
Image showing the Greseng MH-D30 tubes
Greseng MH-D30: Conversion architecture and analogue stage
The conversion section utilises an SPHE8104 DAC chip to convert the digital signal to analogue, whilst four Texas Instruments 5532 operational amplifiers handle signal conditioning and ensure output stability. This architecture is complemented by a Beijing 6S6 tube stage positioned at the output, which influences the sound signature without altering the frequency response or introducing measurable distortion, but delivers a richer and more delicate sound. The system guarantees a dynamic range of 108dB and a signal-to-noise ratio of 105dB, ensuring stable reproduction in a variety of Hi-Fi setups.
Greseng MH-D30: Mechanical design and application
The aluminium chassis provides structural rigidity, minimising vibrations that could affect the playback mechanism. An infrared remote control is supplied with the unit, allowing for remote operation, whilst the Samsung VFD display ensures clear readability of playback information. In addition, it features a memory function so you can resume playback from where you left off in the event of an interruption. Finally, a small window allows you to see the tubes in operation.
Image showing the Greseng MH-D30 remote control
Front view of the Greseng MH-D30
Details of the front panel of the Greseng MH-D30
1Power switch
2Headphone output volume
3Window tubes
4USB-A Port
5Headphone jack 3.5mm output
6Open / Close CD player
7Play / Pause
8Stop
9Previous Track
10Next Track
11Switch Mode
Back view of the Greseng MH-D30
Details of the back panel of the Greseng MH-D30
1Balanced XLR output
2Single-ended RCA output
3Balanced XLR output
4Coaxial output
5Optical output
6Bluetooth antenna
7Power supply interface
Product typeCD Player
InputsCD player
1x USB-A (flash drive up to 128GB)
Bluetooth 5.2
2x Balanced stereo XLR
1x Coaxial
1x Toslink optical
1x 3.5mm Jack headphone output
Processor / DACSPHE8104
Tubes2x Beijing 6S6
Operational Amplifier Chip4x Texas Instrument 5532
ScreenVFD
Formats supported via USBAPE / FLAC / WAV / MP3 / WMA
Supported Bluetooth codecsaptX HD / aptX / AAC / SBC
Supported CD formatsAACDTS / CD / MP3 / CD-R / RW / WMA / MP3 / AAC
Output level2.0V
Frequency response20Hz-20kHz
Total harmonic distortion plus noise (THD+N)0.0020% (24bits)
0.0025% (16bits)
Dynamic range108dB (16-24bits)
Signal-to-noise ratio (SNR)105dB
Supply voltage110-220V AC, Max 25W
Dimensions430x330x80mm
Frame materialAluminium
Weight6.8kg
Package1x Greseng MH-D30
1x Power cable
1x Bluetooth Antenna
1x Remote control
InputCD
OutputOptical Toslink
OutputJack 3.5mm
OutputCoaxial SPDIF
DAC / ADC ChipSPHE8104
Max sampling rateNC
Remote ControlYes
GRESENG MH-D30 Tubes CD Player DTS HD Bluetooth 5.2
The Greseng MH-D30 is a tube CD player designed to handle the playback and conversion of digital sources within a hi-fi system. It is based on a...
