MCGEE CD-M1 CD Player Sanyo DA11 Burr-Brown PCM1732
The McGee CD-M1 is a high-end CD player, based on the high-quality Sanyo DA11 optical drive, installed in a robust aluminium case. The player has a full range of connections with two stereo RCA outputs as well as Optical Toslink and Coaxial outputs. The digital/analog conversion of the CD-M1 is done by a Burr-Brown PCM1732 DAC chip.
By buying this product you get 61 loyalty points
Reference : 15675
615,00 €tax incl.
512,50 € tax excl.
McGee CD-M1
Lecteur CD Sanyo DA11 Burr-Brown PCM1732
McGee CD-M1 Lecteur CD Sanyo DA11 Burr-Brown PCM1732
The power stage of the CD-M1 is also optimized and totally separated from the player so that no interference can alter the audio signal.
Product typeCD Player
Optical driveSanyo D11
DAC ChipBurr-Brown PCM1732
Outputs2x Stereo RCA
1x Optical Toslink
1x Coaxial
THD< 0.008%
Output impedance800Ω
SNR> 90dB
Supply voltage230VAC 50Hz
ConsumptionMax : 35W
Idle : 6.9W
Dimensions351 x 258 x 74mm
Weight4.5kg
Housing materialAluminum
Package1x McGee CD-M1
1x Power cable
1x Remote control
2x RCA Cables (L/R)
The McGee CD-M1 is a high-end CD player, based on the high-quality Sanyo DA11 optical drive, installed in a robust aluminium case. The player has a...
