SHANLING CT90 CD Transport MQA-CD Black
The Shanling CT90 is a high-fidelity CD transport. It is based on a Sanyo DA11 playback system and a SAA7826 decoder for the most faithful reproduction. It supports high-resolution streams up to PCM 32bit 768kHz, DSD512, and MQA-CD with upsampling. In addition, it features Bluetooth 5.0 with support for high-resolution AAC, SBC, aptX, aptX HD, and LDAC codecs.
By buying this product you get 82 loyalty points
Reference : 21404
829,00 €tax incl.
690,83 € tax excl.
Shanling CT90 Transport Bluetooth 5.0 LDAC 32-bit 768kHz DSD512 MQA-CD Black
Photo of the Shanling CT90
The Shanling CT90 is a high-fidelity CD transport. It is based on a Sanyo DA11 playback system and a SAA7826 decoder for the most faithful reproduction. It supports high-resolution streams up to PCM 32bit 768kHz, DSD512, and MQA-CD with upsampling. In addition, it features Bluetooth 5.0 with support for high-resolution AAC, SBC, aptX, aptX HD, and LDAC codecs. The modern Eddict Player app also allows you to fully control the CT90. In terms of connectivity, there is a USB-B transport input, as well as numerous digital outputs, including an I2S LVDS output via HDMI. A BNC input also offers the possibility of using an external clock. The whole unit is powered by a 35W linear power supply consisting of an audiophile-grade toroidal transformer.
Shanling CT90: MQA-CD support
The Shanling CT90 supports the MQA format with various options. It offers full support (4x), basic support (2x), and an MQA source mode to adapt to the DAC that would come next in the audio chain.
MQA INDICATOR
MQA typeLED indicator
MQAGreen
MQA StudioBlue
MQA renderingPurple
MQA CD support by the CT90
Shanling CT90: Dedicated upsampling chip
With its dedicated CT7302 upsampling chip, the CT90 can adapt the signal to almost any PCM or DSD DAC.
Please note that upsampling is not available on the USB output. Upsampling is possible via I2S up to PCM 32bit 768 kHz and DSD512, but also via AES/EBU or coaxial SPDIF up to PCM 24bit 192 kHz and DSD DoP64.
CT90 clock
Shanling CT90: Audiophile clocks
The CT90 uses two 45MHz / 49MHz oscillators to radically optimize jitter and deliver a highly accurate digital signal.
Shanling CT90 : Bluetooth 5.0
The Shanling CT90 features a Bluetooth input and supports high-definition AAC, SBC, aptX, aptX HD, and LDAC codecs for fast, high-quality wireless playback.
Bluetooth functionality of the CT90
CT90 compatibility with Eddict Player App
Shanling CT90 : Eddict Player App
Available on Android and iOS, the Eddict Player app lets you control the CT90 for simplified playback of your discs or files thanks to an ergonomic and practical interface.
Shanling CT90 overview
Overview of the Shanling CT90
1CD holder
24.8-inch screen
3USB-A Host
4Control buttons
5Bluetooth antenna
6IEC mains power supply
7USB-B input
8I2S LVDS output via HDMI
9USB-A output
10Coaxial output
112x AES/EBU output
12BNC connector for external clock
Product typeCD transport
Reading systemDA11 read head + SA7826 servo
Compatible disc formatsCD, CD-R, CD-RW
InputsCD
1x USB-B
1x USB-A (HOST)
Bluetooth
Outputs1x I2S LVDS via HDMI
1x USB-A
1x Coaxial
2x AES/EBU
Other exempleBNC for external clock
Supported sampling rateUSB: up to PCM 32bit 768 kHz, DSD up to DSD512 (upsampling not supported)
I2S: PCM up to 32bit 768 kHz, DSD up to DSD512
Coaxial and AES/EBU: PCM up to 24bit 192kHz, DSD DoP64
Supported Bluetooth codecsAAC, SBC, AptX, AptX HD et LDAC
USB Drive audio format supportDSD (.iso*, .dsf, .dff)
*Please note: does not support DST encoded in ISO files
ISO/DXD/APE/FLAC/WAV/AIFF/AIF/DTS/MP3/WMA/AAC/OGG/ALAC/MP2/M4A/AC3/M3U/M3U8/OPUS
GÉNéral
Power supply100-240V AC
Dimensions28 x 23 x 9.1cm (including top cover and feet)
Weight3.5kg
Package1x Shanling CT90
1x AC power cable
SHANLING CT90 CD Transport Bluetooth 5.0 LDAC 32bit 768kHz DSD512 MQA-CD Black
The Shanling CT90 is a high-fidelity CD transport. It is based on a Sanyo DA11 playback system and a SAA7826 decoder for the most faithful...
