Suite à mon avis du 31/01/24 le défaut des timbres à finit par disparaitre . conclusion : attendre un rodage important avant tout jugement . Son homogène et naturel au final .
By buying this product you get 35 loyalty points
The Shanling EC Mini is a CD player and DAP combo that's as compact as it is versatile and high-performance. Its high-quality design allows you to enjoy your music in every detail, whether at home or on the move. What's more, the EC Mini boasts full connectivity, enabling it to function as a USB DAC or preamplifier, and even two-way Bluetooth 5.0 connectivity.
The EC Mini sets a new trend for CD players, integrating a host of modern features in a compact format, for use both at home and on the move. You can enjoy your favorite CDs without the limitations of a conventional player.
Based on the use of a pair of ESS ES9219 DAC chips within a totally balanced architecture, Shanling's EC Mini is capable of delivering rich, faithful sound to bring out the best in your music. What's more, these chips support high-resolution audio streams as well as MQA-CD files.
The EC Mini's circuitry uses high-quality electronic components to enhance its sound reproduction. These include an LTA8092 amplifier, two RT6863 headphone amplifiers, low-noise, low-phase KDS oscillators and Panasonic and ELNA capacitors.
While CD playback can be controlled using the EC Mini's physical buttons, the device's 2.3" touchscreen offers additional control functions. Overall, the player is designed to provide excellent ergonomics for intuitive use and a very good user experience.
| 1 | Jack 3.5mm single-ended headphone output |
| 2 | Jack 4.4mm balanced headphone output |
| 3 | ON/OFF button |
| 4 | Input selection |
| 5 | Play Pause |
| 6 | CD player |
| 7 | Stop / Eject |
| 8 | Volume - |
| 9 | Volume + |
| 10 | Bluetooth antenna |
| 11 | USB-C charging port |
| 12 | USB-C audio port |
| 13 | Micro SD slot |
| 14 | Pre-Out RCA |
With its two built-in 18650 batteries for a total capacity of 6800mAh, the Shanling EC Mini provides excellent autonomy, enabling it to be used without an external power supply for up to 25 hours for playback from a Micro SD card, or up to 7.5 hours for CD playback. Charging is via a standard USB-C cable.
The Shanling EC Mini's built-in CD player is a high-performance Philips model, combined with a Sanyo HD860 laser head. This combination ensures accurate playback of CDs and MQA-CDs. What's more, the unit features a vibration-damping system to prevent stalling during playback.
The EC Mini is based on the Ingenic X1000 platform, enabling the device to deliver a wide range of functions and fast data processing. This is combined with the proprietary MTouch system for smooth music playback.
| Specifications | |
| Product type | CD player and DAP |
| Inputs | CD player 1x Micro SD slot 1x USB-C (USB DAC) Bluetooth |
| Outputs | 1x Single-ended Jack 3.5mm headphone output 1x Balanced Jack 4.4mm headphone output 1x Pre-Out RCA 1x USB-C Bluetooth |
| Bluetooth version | 5.0 |
| Supported Bluetooth codecs | Reception: SBC, AAC, LDAC Transmission: SBC, AAC, aptX, LDAC |
| Battery capacity | 6800mAh |
| Battery life | Micro SD: up to 25h CD player: up to 7.5h |
| Touchscreen | LCD 2.33" |
| Supported file formats (Micro SD) | DSD (.iso, .sdf, .dff) / DXD / APE / FLAC / WAV / AIFF / AIF / DTS / MP3 / WMA / AAC / OGG / ALAC / MP2 / M4A / AC3 / OPUS / TAK / CUE |
| Supported sampling rates | PCM up to 32bit 384kHz DSD up to DSD256 |
| DAC chips | 2x ES9219MQ |
| RCa output | |
| Output level | 2.1Vrms |
| Frequency response | 20Hz - 40kHz (-0.1dBà |
| THD+N | 0.0005% |
| Channel separation | 110dB |
| Dynamic range | 114dB |
| SNR | 114dB |
| Jack 3.5mm output | |
| Output power | 140mW @ 32Ω |
| Frequency response | 20Hz - 40kHz (-0.1dB) |
| THD+N | 0.0006% |
| Channel separation | 76dB |
| Dynamic range | 120dB |
| SNR | 120dB |
| Noise | > 113dB |
| Impedance | < 1Ω |
| Jack 4.4mm output | |
| Output power | 248mW @ 32Ω |
| THD+N | 0.0005% |
| Channel separation | 115dB |
| Dynamic range | 123dB |
| SNR | 123dB |
| Noise | > 110dB |
| Impedance | < 1Ω |
| General | |
| Dimensions | 250*205*52mm |
| Weight | 1.2kg |
| Color | Silver |
| Input | Bluetooth |
| Input | CD |
| Input | USB |
| Input | Micro SD |
| Output | USB |
| Output | Jack 3.5mm |
| Output | Bluetooth |
| Output | RCA |
| Output | Jack 4.4mm |
| DAC / ADC Chip | ES9219MQ/Q |
| Max sampling rate | MQA |
| Max sampling rate | DSD256 |
| Max sampling rate | 384kHz |
| Color | Silver |
Average votes 5.0 / 5 2 reviews | Why write products reviews ? You can share your feelings about products and help other people by sharing your experience |
jérome M.
jérome M.
