The RM1 combines the left and right audio channels into a single mono signal. As a result, it does not offer a stereo output.
The Syitren RM1 is a CD player portable with a transparent chassis, designed to make its internal circuits visible while playing CDs. Its custom mechanism, combined with three-point silicone damping and electronic anti-skip protection, contributes to steady playback.
Intended for listening on headphones or speakers, it combines Bluetooth 5.3, a 3.5mm jack output and a 2000mAh rechargeable battery. Its stand allows it to be placed on furniture or mounted on the wall, making the RM1 a player that fits into a listening space as well as a collection display.
The Styitren RM1 is a portable CD player distinguished by its transparent frame, fully revealing its internal circuits and playback mechanism. This design makes the device both a listening device and a visual element: it can be placed on a desk or piece of furniture using the supplied stand, or mounted on the wall to display a CD collection. Its dot-matrix display shows the track number and playback progress, while the remote control provides access to single-track repeat, sequential playback and shuffle modes. The display can also be hidden or cycled through different patterns.
The RM1 features a custom CD mechanism combined with electronic anti-skip protection. A three-point silicone damping system limits vibrations transmitted to the mechanism, helping to maintain steady playback. These features support use of the player on a desk or mounted on the wall.
To adapt to different listening equipment, the Styitren RM1 transmits sound via Bluetooth 5.3 to compatible headphones or speakers. Its 3.5mm jack audio output also allows a wired connection to headphones or powered speakers, particularly when you want to listen to a disc without using a wireless link.
The 2000mAh rechargeable battery provides approximately 6 to 8 hours of playback, allowing the RM1 to be used without being connected to a power supply. The USB-C port charges it in approximately 1 to 2 hours, while a dedicated indicator shows the remaining battery level.
Technical specifications
| Specifications | |
| Product type | CD player |
| Outputs | 1x Jack 3.5mm Bluetooth |
| Frequency response | 20Hz-20kHz |
| THD+N | -75dB |
| Crosstalk | -80dB |
| Output level | 1Vrms |
| Dynamic range | 90dB |
| SNR | 95dB |
| Output power | ≥11mW @ 32Ω |
| Bluetooth version | 5.3 |
| Supported Bluetooth codecs | SBC |
| Compatible disc formats | CD MP3 WMA |
| DAC chip | M5673D |
| Battery | 2000mAh |
| Autonomy | 6-8h |
| Charging time | 1-2h |
| General | |
| Supply voltage | 5V DC / 1A |
| Dimensions | 260 x 260 x 48mm |
| Weight | 0.9kg |
| Color | Transparent |
| Package | 1x Styitren RM1 1x Remote control 1x USB-C cable 2x Support feet |
