IAN CANADA 22C SMT XO Clock Adapter
This SMT XO 22C adapter module from Ian Canada, precision-engineered and manufactured to the highest standards, features custom-made gold-plated SMT pins that are robust and durable, perfectly matched to XO sockets, with pre-mounted power cleaning capacitors and a fully assembled PCB ready for use, making integration simple and clean. This adapter is compatible with SMT XO clocks measuring 7.5x5mm, 5.0x3.mm2, 3.2x2.5mm, and 2.5x2.0mm.
Reference : 21028
32,91 €tax incl.
27,42 € tax excl.
Shipping date: 17-11-2026.
Ian Canada 22C SMT XO Clock Adapter (Pair)
Ian Canada 22C : Pair seen from the front
Ian Canada 22C: Assembly instructions
Prepare both the precision SMT XO adapters and SMT XO clocks. Fill both the pads of adapter PCB and SMT pins of clock with thin layer of solder.
To solder the SMT XO to the adapter, please using a soldering iron with fine tip. Get started from pin1, fix the XO carefully to ensure it is at the desired center position.
The better alternative solution would be the hot air rework station. In this case, you just need to fill the pads of the adapter PCB with soldering paste and then use the hot air to solder the SMT clock. But please cover the pin positions with high temperature tape to protect the pins.
Ian Canada 22C with clock mounted
Proper use of this DIY kit requires knowledge of electronics and soldering. Incorrect installation could impair the proper functioning of the product and the device on which it is mounted.
Product typeSMT XO Clock Adapter
Pin platingGold
PackageSold by pair
IAN CANADA 22C SMT XO Clock Adapter (Pair)
This SMT XO 22C adapter module from Ian Canada, precision-engineered and manufactured to the highest standards, features custom-made gold-plated...
