1.3ps +/-20ppm LVCMOS
This 24.576Mhz clock provides stability and accuracy for low jitter. It has a LVCMOS output format to the SMD / SMT standard.
It will replace any compatible 24.576Mhz clock, offering performances close to American, British or Japanese references, for a much lower price.
The benefits of a quality clock are well known to audiophiles, offering a less aggressive sound on high definition files.
Caution: This clock requires a soldering station suitable for hot air type SMD components. Do not attempt to solder with a conventional soldering iron.
| Specifications | |
| Frequency | 24.576Mhz |
| Frequency stability | +/-20ppm |
| Phase jitter | 1.3ps |
| Voltage supply | 1.8, 2.5 à 3.3V |
| Output type | LVCMOS |
| Connection type | SMD/SMT |
| Operating temperature | -55°C to 125°C |
| Dimensions | 7 x 5 x 0.85mm |
