I used the Exicon transistor as a replacement for the discontinued SK1058 transistor. No need for any circuit modifications.
Transistor MOSFET 2SK1058
Exicon MOSFETS have been specifically designed for high power linear use. They offer high voltage capability, high slew rate and low distortion, making them the ideal choice for audio amplifier design. Their operating and thermal stability makes them extremely reliable and eliminates the need for a protection circuit. These advantages, combined with high bandwidth, low power requirements and easy paralleling, make it easy to build robust amplifiers with excellent sound characteristics.
The EXC10N20 is an excellent equivalent of the 2SK1058, with improved performance:
| Specifications | |
| Product type | MOSFET |
| Number of pins | 3 |
| Package | TO-247 |
| maximum ratings (Tc = 25°C) | |
| Drain-Source voltage (Vdss) | 200V |
| Gate-Source voltage (Vgss) | +/-14V |
| Continuous drain current (Id) | 8A |
| Body drain diode current (Idr) | 8A |
| Allowable power dissipation * Tcase=25°C (Pd) | 125W |
| Channel temperature(Tch) | 150°C |
| Storage temperature range (Tstg) | -55°C à 150°C |
| Electrical characteristics (TC = 25°C) | |||||
| Symbol | Parameters | Test conditions | Min. | Typ. | Max. |
| BVdsx | Drain-Source breakdown voltage | Vgs = 10V Id = 10mA | 200V | - | - |
| Vgs(off) | Gate-Source cut-off voltage | Vds = 10V Id = 100mA | 0.15V | - | 1.5V |
| Vds(sat) | Drain-Source saturation voltage | Vgd = 0 Id = 8A | - | - | 10V |
| Idsx | Drain-Source cut-off current | Vgs = 10V Vds = 200V | - | - | 10mA |
| Dynamic characteristics | |||||
| Ciss | Input capacitance | - | - | 500pF | - |
| Coss | Output capacitance | Vgs = 0 | - | 300pF | - |
| Crss | Reverse transfer capacitance | f = 1MHz | - | 10pF | - |
| Ton | Turn-on time | Vds = 20V | - | 100ns | - |
| Toff | Turn-off time | Id = 7A | - | 50ns | - |
Average votes 5.0 / 5 4 reviews | Why write products reviews ? You can share your feelings about products and help other people by sharing your experience |
Andre K.
ciro p.
Peter R.
