ARYLIC LA50 Connected Amplifier Stereo
The Arylic LA50 is a connected amplifier that integrates the main streaming protocols, AirPlay 2, Google Cast, Spotify Connect, TIDAL Connect and Roon Ready, making it particularly suitable for multi-room operation. Its dual-band Wi-Fi and Bluetooth 5.4 network connectivity ensures stable and versatile use, whether for high-quality streaming or occasional connections.
By buying this product you get 34 loyalty points
Reference : 21297
349,00 €tax incl.
290,83 € tax excl.
Shipping date: 05-05-2026.
Arylic LA50 Connected Amplifier Stereo WiFi Bluetooth 2x50W 4Ω
Arylic LA50 : Front view
Thanks to its HDMI eARC input with CEC support, the LA50 integrates seamlessly into a compact home cinema system, allowing direct volume control via the television remote control. It also features a wide range of connections, including RCA, optical, USB DAC, USB Host and subwoofer output, enabling it to cover a large number of possible configurations. The ESS9023P DAC and internal DSP ensure clean and consistent reproduction of signals up to 24bit 192kHz PCM.
Compact and easy to integrate, the LA50 features TPA3116D2 amplification delivering 2x 50 W under 4Ω, enabling it to efficiently power a wide range of passive speakers. The dedicated app, available on iOS and Android, provides precise control with multi-room management and a 10-band equaliser.
Product typeConnected amplifier
Inputs1x USB-C
1x USB-A
1x RJ45
1x HDMI eARC
1x Optical Toslink
1x Stereo RCA
Outputs2x Speaker terminals
1x SUB output
DAC chipESS9023P
Supported sampling ratesPCM up to 24bit 192kHz
Amplification chipTPA3116D2
Output power2x50W @ 4Ω
Frequency response20Hz-20kHz (±1dB)
Total harmonic distortion (THD+N)< 0.1%
Signal-to-noise ratio (SNR)> 93dB
Crosstalk> 75dB
DSPBP1048B2
Transmission protocolsGoogle Cast
AirPlay
TIDAL Connect
Spotify Connect
Roon Ready
Qobuz connect
WiFiDual-Band 2.4GHz & 5GHz
Ethernet10/100M RJ45
Bluetooth5.4
Supported codecsSBC
AAC
Trigger
Power supply12-24V DC
Dimensions148 x 148 x 43mm
Package1x Arylic LA50
1x Remote control
1x Power cable
InputRJ45
InputHDMI eARC
OutputSpeaker terminal
OutputSubwoofer
Channel2 (Stereo)
Amplifier chipTPA3116D2
Power (W)50.0
Remote ControlYes
ARYLIC LA50 Connected Amplifier Stereo WiFi Bluetooth 2x50W 4Ω
The Arylic LA50 is a connected amplifier that integrates the main streaming protocols, AirPlay 2, Google Cast, Spotify Connect, TIDAL Connect and...
