The Arylic LA50 is a connected amplifier that integrates the main streaming protocols, AirPlay 2, Google Cast, Spotify Connect, TIDAL Connect and Roon Ready, making it particularly suitable for multi-room operation. Its dual-band Wi-Fi and Bluetooth 5.4 network connectivity ensures stable and versatile use, whether for high-quality streaming or occasional connections.
Thanks to its HDMI eARC input with CEC support, the LA50 integrates seamlessly into a compact home cinema system, allowing direct volume control via the television remote control. It also features a wide range of connections, including RCA, optical, USB DAC, USB Host and subwoofer output, enabling it to cover a large number of possible configurations. The ESS9023P DAC and internal DSP ensure clean and consistent reproduction of signals up to 24bit 192kHz PCM.
Compact and easy to integrate, the LA50 features TPA3116D2 amplification delivering 2x 50 W under 4Ω, enabling it to efficiently power a wide range of passive speakers. The dedicated app, available on iOS and Android, provides precise control with multi-room management and a 10-band equaliser.
| Specifications | |
| Product type | Connected amplifier |
| Inputs | 1x USB-C 1x USB-A 1x RJ45 1x HDMI eARC 1x Optical Toslink 1x Stereo RCA |
| Outputs | 2x Speaker terminals 1x SUB output |
| DAC chip | ESS9023P |
| Supported sampling rates | PCM up to 24bit 192kHz |
| Amplification chip | TPA3116D2 |
| Output power | 2x50W @ 4Ω |
| Frequency response | 20Hz-20kHz (±1dB) |
| Total harmonic distortion (THD+N) | < 0.1% |
| Signal-to-noise ratio (SNR) | > 93dB |
| Crosstalk | > 75dB |
| DSP | BP1048B2 |
| Transmission protocols | Google Cast AirPlay TIDAL Connect Spotify Connect Roon Ready Qobuz connect |
| WiFi | Dual-Band 2.4GHz & 5GHz |
| Ethernet | 10/100M RJ45 |
| Bluetooth | 5.4 |
| Supported codecs | SBC AAC |
| Trigger | |
| General | |
| Power supply | 12-24V DC |
| Dimensions | 148 x 148 x 43mm |
| Color | Black |
| Package | 1x Arylic LA50 1x Remote control 1x Power cable |
| Input | USB |
| Input | Optical |
| Input | HDMI eARC |
| Input | RCA |
| Input | RJ45 |
| Output | Speaker terminal |
| Output | Subwoofer |
| Color | Black |
| Channel | 2 (Stereo) |
| Class | Class D / T |
| Amplifier chip | TPA3116D2 |
| Power (W) | 50.0 |
| Remote Control | Yes |
