IAN CANADA HDMIPRO II I2S LVDS HDMI Interface Module
Ian Canada's HdmiPi Pro II is an I2S/DSD interface module via HDMI. It is the first solution to use a discrete 1bit LVDS driver to achieve the best HDMI signal quality and the lowest noise levels. The module also incorporates the highly acclaimed 1bit discrete secondary reclockers (similar to ReClockPi) to ensure very low jitter. In short, the HdmiPi Pro II is the ultimate I2S HDMI interface for audiophiles wishing to enhance the sound quality of an external DAC.
Reference : 18717
179,00 €tax incl.
149,17 € tax excl.
Shipping date: 02-05-2025.
Ian Canada HdmiPi Pro II Ultra Low Jitter I2S LVDS HDMI Interface 32bit 1536kHz DSD1024Ian Canada HdmiPi Pro II
HdmiPro key features:
  • Discreet 1bit LVDS driver for the best possible LVDS signal quality and very low noise levels.
  • Integrated discrete 1bit secondary reclocking stage.
  • Improved power filtering.
  • LDO-free design allows use of 3.3V battery or supercapacitor power supplies for improved power supply performance.
  • Impedance control optimized for high-speed LVDS signals.
  • Four-layer PCB with dedicated shielding layers to eliminate EMI noise.
  • Ultra-low-noise metal-film resistors to ensure the lowest possible noise level.
  • PCM streams supported up to 1536kHz.
  • Native DSD streams supported up to DSD1024.
HdmiPro II new features:
  • Format HDMi configurable, fonctionne avec tous les DACs disposant d'une entrée I2S/DSD via HDMI, même s'ils ne sont pas compatibles avec le format PS Audio standard.
  • Optimized reclocking process.
  • Optimized decoupling network for local power supply.
  • Dedicated MUTE/DSDEN control connector for direct connection to the new FifoPi Q7 II (sold separately).
  • Mounting bracket for HDMI connector.
The HdmiPi Pro II operates in SYNC clock mode and must therefore be paired with a FifoPiMa, FifoPiQ7 or FifoPiQ3 (sold separately).
Ian Canada HdmiPi Pro II : Schéma
Product typeI2S interface
InputGPIO
OutputI2S LVDS via HDMI
Supported sampling ratesPCM up to 32bit 1536kHz
DSD up to DSD1024
Supply voltage3.3V
Dimensions95 x 56.5mm
Mounting holes spacing58 x 49mm
InputGPIO
Max sampling rate1536kHz
Max sampling rateDSD1024
Interface chipNC
IAN CANADA HDMIPI PRO II Ultra Low Jitter I2S LVDS HDMI Interface 32bit 1536kHz DSD1024
Ian Canada's HdmiPi Pro II is an I2S/DSD interface module via HDMI. It is the first solution to use a discrete 1bit LVDS driver to achieve the...
