Ian Canada's ReceiverPi Pro II is designed for Raspberry Pi-based DDC or DAC projects, to retrieve a digital audio stream from multiple sources rather than from the Raspberry Pi itself. The ReceiverPi Pro II can select a digital signal from any of the following inputs: coaxial, Toslink optical, I2S via HDMI or Raspberry Pi GPIO.
The ReceiverPi Pro II features an additional control input that can be connected directly to a MonitorPi Pro (sold separately), which functions as an integrated control center. The ReceiverPi Pro II's PCB layout has also been optimized, so there's no problem when it's installed just below a FifoPiQ7 (sold separately). It can also work with a StationPi Pro (sold separately).
Key features:
Product type | SPDIF / I2S receiver |
Inputs | 1* Optical Toslink 1* Coaxial 1* I2S/DSD via HDMI (pinout PS Audio) 1* GPIO |
Outputs | 1* GPIO 1* MCLK sur connecteur U.FL coaxial |
Dimensions | 65*56.5mm |
Mounting holes spacing | 58*49mm |
Input | I2S via HDMI |
Input | SPDIF |
Input | I2S |
Input | Optical |
Output | GPIO |
DAC / ADC Chip | NC |
Max sampling rate | 768kHz |
Max sampling rate | DSD1024 |
