AUDIOPHONICS DAC Sabre ES9023 V2.2 I2S to Analogue 24bit / 192kHz
Audiophonics DAC Sabre ES9023 V2.0 I2S vers Analogique 24bit/192KHZ
A converter with an unbeatable price-performance ratio and direct analog outputs, this module is ideal for all DIY applications. Equipped with the now famous SABRE ES9023 (equipping our U-SABRE), Ultra low noise "ON" regulator and OS-CON capacitor.
4.7 / 5
Reference : 8396
13,25 €tax excl.
Available
Shipping date: 27-06-2019.
Orders placed before 1pm (GMT+1) will be shipped the same day (working day).
AUDIOPHONICS DAC ES9023 V2.2
Sabre ES9023 DAC I2S to Analog 24bit/192kHz
Audiophonics DAC Sabre ES9023 V2.2 I2S vers Analogique 24bit/192kHz
A converter with an unbeatable price-performance ratio and direct analog outputs, this module is ideal for all DIY applications. Equipped with the now famous SABRE ES9023 (equipping our U-SABRE), Ultra low noise "ON" regulator and OS-CON capacitor this DAC will offer you a musical sound and rich in micro details. Its high versatility allows it to also be used directly at the output of a Raspberry PI via the GPIO.
Usable WITH :
Volumio
piCorePlayer
Dimensions
Product typeDAC
ConversionESS ES9023
InputI2S
Supported sampling rateUp to 24bit 192kHz
Space available for additional clock-
I2S ConnectionOrange : MCLK
Yellow : GND
White : DATA
Red : LRCK
Black : BCK
Power supply connectionBlack : GND
Red : +5V
Dimensions53.2 x 47.4mm
Cables1.13mm² / AWG16
Wires0.08mm² / AWG28
Space between fixation holes43.1 x 38.1mm
RCA Spacing20mm
Package1x Audiophonics DAC Sabre ES9023
1x I2S Cable (5 pins)
1x Power supply cable (2 pins)
Example of assembly with a Raspberry Pi
Mounting diagram
InputI2S
Components / ChipES9023
Channel2 channels (Stereo)
Colissimo - TNT - SoColissimo
10 reviews
Bon petit DAC
Très bon DAC utilisé derrière une interface SPDIF. Son très bien restitué. carte facile a mettre en oeuvre. Rien à redire.
This review has been posted for AUDIOPHONICS DAC Sabre ES9023 V2.2 I2S to Analogue 24bit / 192kHz
DAC d'un très bon rapport qualité/prix
Avec oscillateur interne:
Bonne scène sonore. Des grave percutants et profonds.
Mediums et aigus en retraits. Aigus manquants de variations.
Malgré tout une bonne surprise pour sa musicalité.
Avec oscillateur externe (ian McDualXO avec NDK NZ2520SDA):
Grosse amélioration. La scène sonore prend de l'ampleur, plus de largeur et de profondeur.
Les détails apparaissent. Les voix s'expriment mieux. Les aigus s'affinent mais restent en retrait.
Le point faible de ce DAC se situe sur l'extinction des notes qui ne sont pas très naturelles.
Malgré tout un très bon rapport qualité/prix.
Extra !
Son riche et détaillé, aiguës saillants et basses profondes et précises. Attention toutefois dans les extrêmes aux morceaux trop riches, mais rien de grave. (mériterait un Allo Recloker?)
Si ça interesse pour ceux qui ont une imprimante 3D et qui veulent ranimer un vieux raspberry pi model B sous volumio, j'ai modifié un boitier sous tinkercad afin d'intégrer le DAC : https://www.thingiverse.com/thing:2689767
Musicalement votre, et toujours un grand merci à Audiophonics pour cette petite perle :)
Avec l'interface USB LJ CM6631A V 1.3
Câblage entre l’interface USB et le DAC :
DATA -> DATA
GND -> GND
LRCK -> LRCK
SCLK -> BCK
Ne pas connecter MCLK -> MCLK !
Nickel !
DAC de qualité, branché un un vieux Rpi B en I2S avec piCorePlayer avec le schéma de cablage du site (déclaré en Hifiberry), il marche impec !
Attention: les cotes annoncées sont fausses, le modèle reçu mesure 53 mm par 45mm.
Kudos pour audiophonics !
A converter with an unbeatable price-performance ratio and direct analog outputs, this module is ideal for all DIY applications. Equipped with the...
