LHY AUDIO Balanced DAC Board 2x PCM1794A I2S 24bit 192kHz
This simple but beautifully designed balanced DAC module is based on the integration of a pair of PCM1794A digital to analog conversion chips, each dedicated to a channel. These allow it to support sampling rates up to PCM 24bit 192kHz, while delivering a balanced, round and musical sound.
Reference : 16527
59,90 €tax incl.
49,92 € tax excl.
Shipping date: 26-05-2026.
Balanced DAC Board
Module DAC symétrique 2x PCM1794A I2S 24bit 192kHz
This simple but beautifully designed balanced DAC module is based on the integration of a pair of PCM1794A digital to analog conversion chips, each dedicated to a channel. These allow it to support sampling rates up to PCM 24bit 192kHz, while delivering a balanced, round and musical sound. This parallel integration also ensures an improvement of the dynamic range and the signal/noise ratio, these reaching 132dB. This conversion section is followed by a beautiful output stage, including four AOP 5532DD and six AOP 5534D.
As for the connections, the module offers an I2S input on solder pads as well as a balanced XLR output and a single-ended RCA output. Another output can be added thanks to the soldering pads present between the connectors already in place.
Product typeDAC board
DAC Chip2x PCM1794A
Input1x I2S on solder pads
Outputs1x Balanced XLR
1x Single-ended RCA
1x Analog output on solder pad
OPA4x 5532DD
6x 5534DD
Supported sampling ratesPCM up to 24bit 192kHz
Supply voltageDigital stage: 5VDC 0.5A
Analog stage: ±12VDC 0.2A
Dimensions128 x 100mm
Mounting holes spacing120 x 88mm
InputI2S
OutputSolder pad
DAC / ADC ChipPCM1794
Max sampling rate192kHz
2 reviews
Surprise
Surprisingly good sounding dac. And cheap ! With Ian Canada fifopi ,hdmi receiver works smoothly...but clocks must be 22 and 24 MHz ...according to pcm1794 datasheet
This review has been posted for LHY AUDIO Balanced DAC Board 2x PCM1794A I2S 24bit 192kHz
great dac, sounds very nice.
I have played the pcm 1794A dac for about two days now and am very happy with it, plays very nicely and quietly with a nice stereo image.
a side note, I have to upsample with an ian canada FIFO MA 1.5 and ian canada isolator II between a raspberry (volumio as software) otherwise no sound will come out.
otherwise a great dac.
This simple but beautifully designed balanced DAC module is based on the integration of a pair of PCM1794A digital to analog conversion chips, each...
