WONDOM AA-AA21111 DAC/USB Interface Modules
The Wondom AA‑AA21111 is a USB to digital and analogue audio signal converter, designed to directly transform USB stream into S/PDIF and stereo analogue outputs. It leverages standards-compliant Full Speed USB controller and 16 bit delta‑sigma conversion, supporting sampling frequencies of 32, 44.1 and 48 kHz to ensure stable restitution immediately usable in audio chain.
Reference : 22255
9,90 €tax incl.
8,25 € tax excl.
Shipping date: 17-11-2026.
Wondom AA‑AA21111 DAC/USB Interface Modules PCM2404C 16bit 48kHz
Wondom AA‑AA21111 : Front view
Intended for compact systems and simplified integrations, it uses single Micro USB interface ensuring both power and data transfer, thereby enabling cabling reduction while guaranteeing rapid implementation. This approach extends to native driver-free compatibility under Windows and macOS, while integrated RCA outputs and 3.5mm jack facilitate direct connection to amplifier or headphones, ensuring immediate use without additional adaptation.
Product typeDAC module
Interface module
ChipPCM2404C
Input1x Micro-USB
Output1x Optical Toslink
1x RCA
1x 3.5mm jack
Standby consumption0.025W
Maximum current0.5A
Output level1.4V
Supported sample ratePCM 16bit 48kHz
Frequency response20Hz-20kHz
Supply voltage5V
Dimensions91.4 x 68.6mm
Mounting holes spacing83.8 x 61.0mm
Weight30g
PackageSold individually
OutputOptical Toslink
OutputJack 3.5mm
DAC / ADC ChipNC
Max sampling rate48kHz
Interface chipNC
WONDOM AA-AA21111 DAC/USB Interface Modules PCM2404C 16bit 48kHz
The Wondom AA‑AA21111 is a USB to digital and analogue audio signal converter, designed to directly transform USB stream into S/PDIF and stereo...
