WONDOM ASCM‑D2A‑PCM5122 DAC Module
The Wondom ASCM‑D2A‑PCM5122 is an I2S digital-to-analogue converter designed to transform digital audio signal into usable analogue output for amplifier or active speakers. It leverages Texas Instruments PCM5122 DAC to process streams up to 32 bit / 384 kHz, thereby enabling signal restitution with elevated detail level while ensuring stable conversion to single-ended or differential analogue outputs, facilitating integration into existing audio chain.
Reference : 22249
19,00 €tax incl.
15,83 € tax excl.
Wondom ASCM‑D2A‑PCM5122 I2S Module PCM5122 DAC 32bit 384kHz
Wondom ASCM‑D2A‑PCM5122 : Front view
Wondom ASCM‑D2A‑PCM5122: Simplified I2S interface
Support for 3-wire I2S interface, eliminating MCLK signal requirement, simplifies integration while reducing electromagnetic interference within system. This approach limits perturbations linked to multiple clock lines, thereby enabling cleaner signal transmission, particularly in compact environments or those sensitive to EMI emissions.
Wondom ASCM‑D2A‑PCM5122 : DAC chip
Wondom ASCM‑D2A‑PCM5122: Extended compatibility
The module simultaneously delivers analogue outputs in single-ended and differential modes, enabling direct adaptation of signal level and type to connected equipment. This versatility extends to compatibility with ADP‑XAO module for conversion to XLR outputs, thereby facilitating integration into domestic, professional or fixed-installation audio chains without complex intermediate adaptation.
Wondom ASCM‑D2A‑PCM5122 : Installation example
Wondom ASCM‑D2A‑PCM5122: Configurable gain adjustment
Four configurable gain levels (-6 dB, 0 dB, 6 dB, 12 dB) accessible via embedded DIP switches enable precise output level adjustment according to downstream stage sensitivity. This adaptation capability combines with possible battery powering, with dedicated connectors compatible with Wondom BCPB modules, authorizing autonomous integrations while maintaining level and dynamic coherence.
Wondom ASCM‑D2A‑PCM5122 : Compatible module example and adjustable gain
Wondom ASCM‑D2A‑PCM5122: Simplified integration
Integration relies on plug-and-play connectors enabling rapid connection without complex cabling, thereby reducing implementation time and installation error risk. This approach favors direct insertion into existing systems, while preserving clear and scalable architecture for custom configurations.
Wondom ASCM‑D2A‑PCM5122: CE and FCC certified
CE and FCC certified, the module meets electromagnetic compatibility and safety requirements, guaranteeing compliant operation across varied environments. This reliability is strengthened by extended operating range of -20 °C to 65 °C, enabling stable performance maintenance in both domestic and industrial conditions, including constrained environments or those subject to significant thermal variations.
Technical Specifications
Product typeDAC module
Input1x PH I2S connector
Outputs1x Single-ended PH connector
1x Balanced PH connector
Supported sample ratesPCM up to 32bit 384kHz
Output level880mVrms
Load impedance5kΩ
Noise level4.0µVrms
Total harmonic distortion plus noise (THD+N)0.004%
Channel separation-95dB
Signal-to-noise ratio (SNR)108dB
Frequency response20Hz-20kHz
Operating temperature-20°C ~ 65°C
Supply voltage6-24V DC
Dimensions76.2 x 50.8mm
Mounting holes spacing69.9 x 44.5mm
Weight24.3g
PackageSold individually
InputI2S
OutputPH 2.0mm
DAC / ADC ChipPCM5122
Max sampling rate384kHz
WONDOM ASCM‑D2A‑PCM5122 I2S Module PCM5122 DAC 32bit 384kHz
The Wondom ASCM‑D2A‑PCM5122 is an I2S digital-to-analogue converter designed to transform digital audio signal into usable analogue output for...
