WONDOM UCM-D2A-SA9128 Converter Module 7.1 Channel USB 2.0 to 4 Channel I2S / 8 Channel Analog
The WONDOM UCM-D2A-SA9128 is a 7.1-channel multichannel audio converter module designed to convert a USB 2.0 digital audio stream into four I²S outputs or eight analog outputs, enabling the creation of complex audio systems without the need for multiple separate converters.
Reference : 22085
57,90 €tax incl.
48,25 € tax excl.
Wondom UCM-D2A-SA9128 7.1-Channel USB 2.0 to 4-Channel I2S / 8-Channel Analog Converter Module
The Wondom UCM-D2A-SA9128 is a 7.1-channel multichannel audio converter module designed to convert a USB 2.0 digital audio stream into four I²S outputs or eight analog outputs, enabling the creation of complex audio systems without the need for multiple separate converters. It is based on a USB interface using the SA9128 controller and a Texas Instruments PCM5122 digital-to-analog converter, ensuring high performance with a THD+N of 0.007%, a signal-to-noise ratio of 105dB, and an extremely low noise floor of 3.4µVrms. Compatible with 7.1-channel audio streams, it supports USB Audio signals up to 24bit 48kHz and provides I²S outputs in 24bit 48kHz format. Its architecture incorporates complete digital isolation separating signal and power circuits to reduce interference and preserve signal integrity. Operating driver-free under Windows, macOS and Linux, it features Plug & Play operation and requires only a single USB cable for both power and audio transmission. Thanks to its numerous onboard and external interfaces, the UCM-D2A-SA9128 integrates easily into 7.1 home theater systems, multichannel monitoring setups, arcade machines, and advanced DIY audio projects.
Overview of the Wondom UCM-D2A-SA9128
Overview of the WONDOM UCM-D2A-SA9128
1USB-C power / audio input
24x PH 2mm I2S outputs
3DAC 1 LED Connector
4DAC 2 LED Connector
5DAC 3 LED Connector
6DAC 4 LED Connector
7Peripheral I2S connector
8Power and DATA input
94x 3.5mm stereo outputs for 5.1/7.1
104x PH 2mm stereo analog outputs for 5.1/7.1
Technical Specifications
Product TypeMultichannel converter module
USB interfaceSA9128
DAC chips4x PCM5122
InputUSB 2.0
Output8x I2S Outputs for 5.1/7.1 channels
8x PH 2mm Analog Outputs for 5.1/7.1 channels
4x 3.5mm Stereo Outputs
Supported sampling ratePCM 24Bit 48kHz
OS CompatibilityPlug and Play: Windows, MAC, Linux
SNR105dB
THD0.007%
Noise Floor3.4uVrms
Crosstalk-72dB
Power Supply5V 0.5A via USB-C
Package Contents1x Wondom UCM-D2A-SA9128 (2 PCBs)
4x Mounting Standoffs
4x PH-6Pos 2mm Cables
OutputI2S
OutputJack 3.5mm
OutputPH 2.0mm
DAC / ADC ChipPCM5122
Max sampling rate48kHz
The WONDOM UCM-D2A-SA9128 is a 7.1-channel multichannel audio converter module designed to convert a USB 2.0 digital audio stream into four...
