AIYIMA D07 DAC AKM AKM4493SEQ XMOS XU316 32bit 768kHz DSD512
The Aiyima D07 is a DAC based on AKM AK4493SEQ architecture combined with a third-generation XMOS XU316 interface, designed to handle high-resolution audio streams up to 32bit 768kHz and DSD512. This hardware combination utilizes the Velvet Sound architecture to linearize playback while reducing background noise, thereby preserving harmonic richness and the coherence of micro-details in high-density audio files.
Reference : 21917
104,91 €tax incl.
87,42 € tax excl.
Shipping date: 13-11-2026.
Aiyima D07 DAC AKM AK4493SEQ XMOS XU316 32bit 768kHz DSD512
Miniature of the Aiyima D07
Designed for integration into a HI-FI system or computer environment, it combines USB, optical, and coaxial inputs with a dual RCA output, allowing it to adapt to various sources while maintaining a consistent signal level. This approach is complemented by switchable DAC or DAC with preamplification modes and multi-OS compatibility, making it easy to integrate into a variety of systems without any installation constraints.
Aiyima D07: Detailed Sound and Listening Experience
The Aiyima D07 is powered by the AKM AK4493SEQ chip, which features Velvet Sound technology for a warm sound, rich music, and a natural listening experience.
It features a third-generation XMOS XU316 processor that supports high-resolution audio streams up to PCM 32bit 768 kHz and DSD512, ensuring full compatibility with even the most demanding audio files.
Image showing the chips in the Aiyima D07
Photo of the AOP chip replacement on the Aiyima D07
Aiyima D07: Design and Customization
Based on the design of the A07 MAX series, the D07 is designed to be compact and ideal for stacking, thanks to its CNC-machined chassis, which provides enhanced protection against electromagnetic interference.
In addition, the interior is designed to allow for easy replacement of the DIP8 operational amplifier chips, enabling users to customize their listening experience. The D07 comes equipped with a NE5532P operational amplifier as standard.
Aiyima D07: Connectors and Interface
To accommodate a wide variety of inputs, the D07 features three inputs—USB, optical, and coaxial supporting most audio sources. A button allows you to easily switch between three audio source modes, while a button on the back lets you toggle between DAC mode and DAC + Preamplifier mode.
The device is primarily designed to work with as many systems as possible, as it is compatible with operating systems such as Windows, Mac, and Linux. The USB port allows you to switch between UAC 1.0 and 2.0. UAC 1.0 mode ensures compatibility with game consoles.
Photo des connectiques du Aiyima D07
Overview of the Aiyima D07
Schéma du Aiyima D07
1DSD audio format indicator
2UAC 1.0 mode indicator
3Input indicator
4Volume knob
5Output channel switch
6UAC 1.0 / 2.0 switch
7Bypass
8RCA Output 1
9RCA Output 2
10Coaxial input
11Optical input
12USB / Power input
Product typeDAC
DAC chipAKM AK4493SEQ
USB interfaceXMOS XU316
AOPNE5532P
Inputs1x USB-C
1x Toslink Optical
1x Coaxial
Outputs2x RCA
Supported sampling ratesUSB : PCM 32bits 768kHz, DSD512 (DOP256)
Optical/Coaxial : PCM 24bits 192kHz
OS CompatibilityWindows 10/11, macOS, Linux
RCA Output Level2.0 Vrms
SNR≥ 118dB
THD+N0.0002%
Frequency response20Hz-20kHz (±0.2dB)
Noise level2.3µVrms
Power supplyDC 5V via USB-C
Dimensions130x100x30mm
Weight400g
Package1x Aiyima D07
Specifications Chart for the Aiyima D07
DAC / ADC ChipAK4493SEQ
Max sampling rateDSD512
Max sampling rate768kHz
ColorGray
AIYIMA D07 DAC AKM AK4493SEQ XMOS XU316 32bit 768kHz DSD512
The Aiyima D07 is a DAC based on AKM AK4493SEQ architecture combined with a third-generation XMOS XU316 interface, designed to handle...
