AIYIMA D20 DAC
The Aiyima D20 is a high-resolution DAC featuring dual-chip architecture, combining ES9039Q2M and AK4493S converters with XMOS XU316 USB interface. It supports PCM streams up to 32 bit / 768 kHz as well as DSD512, ensuring conversion of high-definition digital sources to detailed analog output.
By buying this product you get 35 loyalty points
Reference : 22313
359,00 €tax incl.
299,17 € tax excl.
Shipping date: 01-12-2026.
Aiyima D20 DAC ES9039Q2M+AKL4493S Bluetooth 5.1 32bit 768kHz DSD512
Aiyima D20 : Front view
Intended for scalable Hi-Fi installation, it combines high-resolution Bluetooth reception, fully balanced circuit, interchangeable operational amplifiers and volume bypass mode. Its aluminium chassis, 3.4-inch display and UAC 1.0 / 2.0 compatibility facilitate integration with various sources, while independent volume memory maintains appropriate level for each input.
Aiyima D20 : Dual-chip DAC architecture
The D20 adopts digital architecture based on two high-end DAC chips, the ES9039Q2M and AK4493S. This design distributes digital-to-analog conversion processing between two specialized circuits, enabling exploitation of their resources within single conversion section. XMOS XU316 USB interface manages incoming audio streams and enables support for PCM files up to 32 bit / 768 kHz as well as DSD512, for use with high-resolution sources.
Aiyima D20 : DAC chips
Aiyima D20 : Bluetooth codecs
Aiyima D20 : High-resolution Bluetooth reception
Wireless connectivity relies on QCC5125 Bluetooth chip, designed to receive audio streams from smartphone, tablet or computer. The D20 supports LDAC, aptX, aptX HD, aptX Adaptive, AAC and SBC codecs; codec used adapts to source capabilities and transmitting device. This compatibility enables prioritization of more detailed transmission with devices equipped with LDAC or various aptX variants, while maintaining extended compatibility with common Bluetooth sources.
Aiyima D20 : Interchangeable operational amplifiers
Analog section integrates operational amplifiers mounted on DIP8 sockets, enabling replacement without direct intervention on printed circuit board. This arrangement allows adaptation of output configuration to selected components and facilitates maintenance or experimentation with various compatible op-amps. The D20 can thus be used in original configuration or integrated into progressive optimization approach of analog section.
Aiyima D20 : Interchangeable op-amps
Aiyima D20 : Fully balanced circuit
The D20 uses fully balanced architecture throughout signal path, from conversion stages to analog output. This configuration separates positive and negative signal components to limit influence of common-mode disturbances and maintain better channel separation. This design is particularly suitable for installations equipped with balanced analog connection, where DAC is placed between digital source and amplifier or preamplifier with XLR inputs.
Aiyima D20 : Operating diagram
Aiyima D20 : Volume bypass mode
Bypass mode allows disabling volume control integrated in D20 to transmit signal without passing through this level management function. The DAC can then be connected to integrated amplifier or preamplifier already equipped with own volume control. This configuration reduces treatments applied to output signal.
Aiyima D20 : User interface
Aiyima D20 : Chassis, display and user interface
The D20 is housed in aluminium chassis protecting internal circuits while ensuring coherent integration in Hi-Fi chain. Its front panel accommodates 3.4-inch display showing main information regarding source, volume and audio format used. Minimalist user interface groups essential functions on clear presentation, enabling quick input selection or verification of operating status without multiplying menus.
Aiyima D20 : USB compatibility with UAC 1.0 and 2.0 modes
Support for USB Audio Class 1.0 and 2.0 modes enables D20 to work with extended range of digital sources. UAC 1.0 mode favours compatibility with certain older devices or systems, while UAC 2.0 mode enables exploitation of high-resolution formats supported by XMOS XU316 interface. This dual compatibility facilitates integration with computer, network player or USB source without imposing single configuration.
Aiyima D20 : UAC 1.0 and 2.0
Aiyima D20 : Independent volume level
Aiyima D20 : Independent volume memory
The D20 separately stores volume level associated with each input, preserving dedicated setting for each source. When switching from Bluetooth to USB input, for example, device automatically recalls level previously used for that input instead of applying common value. This management limits sound discrepancies when changing source and simplifies daily use in installation grouping multiple devices.
Aiyima D20 Overview
Aiyima D20 : Diagram
1Power button
2IR receiver
3Display
4Volume control
5Standby indicator
6XLR output
7RCA output 2
8Bluetooth antenna
9Optical Toslink input 2
10Optical Toslink input 1
1112V Trigger input
12RCA output 1
13Coaxial input
14HDMI ARC input
15USB-C input
1612V Trigger output
17DC power jack
Technical specifications
Product typeDAC
Inputs1x USB-C
1x Coaxial
2x Optical Toslink
1x HDMI ARC
Bluetooth 5.1
Outputs2x RCA stereo
1x XLR stereo
DAC chipsES9039Q2M
AK4493S
USB interfaceXMOS XU316
Supported sampling ratesPCM up to 32bit 768kHz
Native DSD up to DSD512
Bluetooth chipQCC5125
Supported Bluetooth codecsLDAC
aptX
aptX HD
aptX Adaptive
AAC
SBC
USB compatibilityWindows 10/11
macOS
Linux
Android
iOS
Signal-to-noise ratio (SNR)≥124dB
SINAD≥113dB
Total harmonic distortion plus noise (THD+N)<0.0002%
Dynamic range≥120dB
Frequency response20Hz-20kHz (±0.2dB)
Noise floor≥2μV
Output levelRCA: 2Vrms
XLR: 4Vrms
USB modeUAC 1.0
UAC 2.0
Power supply voltage12V DC
Dimensions190 x 142 x 46mm
Weight950g
ColourBlack
Package contents1x Aiyima D20
1x Remote control
1x Trigger cable
1x USB-A to USB-C cable
1x Optical Toslink cable
1x Power adapter
Aiyima D20 : Measurements
InputHDMI ARC
DAC / ADC ChipES9039Q2M
DAC / ADC ChipAK4493S
Max sampling rateDSD512
Max sampling rate768kHz
Remote ControlYes
Download
AIYIMA D20 DAC ES9039Q2M+AK4493S Bluetooth 5.1 32bit 768kHz DSD512
The Aiyima D20 is a high-resolution DAC featuring dual-chip architecture, combining ES9039Q2M and AK4493S converters with XMOS XU316 USB interface....
