The Douk Audio DAC-Q11 is a unique device featuring two switchable DAC chips. It features an ESS ES9038Q2M chip and an AKM AK4493 chip. Each of these chips supports high-resolution sampling rates up to PCM 32bit 384kHz and DSD256. Users can therefore enjoy both the renowned dynamics of ESS chips and the refined tones of AKM chips. For inputs, there's Toslink optical, SPDIF coaxial and a USB-B port. Outputs are divided into two groups, each comprising an RCA output and a 3.5mm jack auxiliary output. This makes it possible to switch between the DAC's 3 operating modes, allowing you to use the two different DAC chips on each set of outputs, or just one on all outputs. Added to this is a neat aesthetic, worthy of top-of-the-range devices, thanks to a transparent glass panel revealing the Douk Audio DAC-Q11 PCB and two OLED screens for displaying information on the track being played and accessing parameters.
Douk Audio DAC-Q11 operating panel | ||
Operating mode | Output group 1 | Output group 2 |
1 | ES9038Q2M | AK4493 |
2 | AK4493 | |
3 | ES9038Q2M |
1 | Input mode display |
2 | Sampling rate |
3 | Volume progress bar |
4 | Volume display (0-99) |
5 | IR receiver |
6 | Power / input selector / volume control |
7 | Operating mode display |
8 | Output group 1: Aux jack 3.5mm / RCA stereo |
9 | Output group 2: Stereo RCA / Aux jack 3.5mm |
10 | Coaxial input |
11 | Toslink optical input |
12 | USB-B input |
13 | 12V DC power port via DC jack |
Product type | DAC |
Dac chips | ES9038Q2M AK4493 |
Inputs | 1x USB-B 1x Coaxial 1x Toslink optical |
Outputs | 2x Stereo RCA 2x AUX output via 3.5mm jack |
Supported sample rates | USB: PCM up to 32bit 384kHz / DSD up to DSD256 Toslink optical / Coaxial: PCM up to 24bit 192kHz |
THD+N | 0.0003% @ 1kHz |
SNR | ≥ 117dB |
Frequency response | 20Hz-20KHz (±0.3dB) |
USB system compatibility | Windows 7 /Windows 8 / Windows 10 / MAC / Linux |
Output level | AK4493: 1.8V ES9038Q2M: 2V |
Power supply | 12V DC (≥1.5A) via jack DC |
Dimensions | 155 x 125 x 42mm |
Weight | 600g |
Color | Black |
Package | 1x Douk Audio DAC-Q11 1x DC 12V power adapter 1x USB-B to USB-A cable 1x Optical cable 1x Remote control |
Input | SPDIF |
Input | USB |
Input | Optical |
Output | RCA |
Output | Jack 3.5mm |
DAC / ADC Chip | ES9038Q2M |
DAC / ADC Chip | AK4493 |
Max sampling rate | 384kHz |
Max sampling rate | DSD256 |
Color | Black |
Networking | No |
Remote Control | Yes |
