FIIO K17 DAC Headphone Amplifier Black
The FiiO K17 is a high-end DAC and headphone amplifier designed to deliver a comprehensive and versatile audio experience, whether for audiophiles or users looking for an all-in-one device for their home office or living room. It stands out for its balanced architecture, high amplification power, and extensive connectivity, making it a top choice in its class.
By buying this product you get 99 loyalty points
Reference : 21643
990,00 €tax incl.
825,00 € tax excl.
FiiO K17 DAC Headphone Amplifier 2x AK4499EQ WiFi Roon AirPlay Bluetooth 5.4 aptX LDAC 32bit 768kHz DSD512 Black
FiiO K17
FiiO K17: An optimized conversion section
The K17 features a combination of high-quality AKM DAC chips: an AK4191 paired with two AK4499EX chips, each dedicated to a single channel. This configuration enables highly accurate digital-to-analog conversion, with a resolution of up to 32-bit/768 kHz and native DSD512 support. The 8-channel-to-4-channel design reduces common-mode interference, thereby improving channel separation and sound dynamics. The K17 also features a dedicated DSP (MS21586Q) for professional 31-band PEQ tuning, offering advanced sound customization via dedicated PC and mobile apps.
FiiO K17: DAC chips
Fiio K17: Balanced  architecture
Every stage of the signal processing, from digital-to-analog conversion to amplification, is designed to operate in differential mode, ensuring faithful sound reproduction and minimal crosstalk. Many components of the audio circuit, including the I/V converter and the LPF stages, utilize multiple OPA1612 op-amps to deliver excellent dynamic range.
FiiO K17: Balanced architecture
FiiO K17: Amplification stage
FiiO K17: A robust amplification stage
The amplifier stage is based on a discrete circuit using ON Semiconductor MJE243/253 transistors, ensuring high output power (up to 4000 mW) and low output impedance. This allows for the efficient driving of a wide range of headphones and earphones, with an adaptive impedance ranging from 8 to 350 ohms depending on the output type (balanced or unbalanced). Five switchable gain levels are available to accommodate all types of headphones.
FiiO K17: Isolation of critical sections
To preserve signal integrity, the K17 features physical separation of the printed circuit boards (PCBs) dedicated to the digital, analog, and power supply sections. This isolation prevents interference between the different parts of the device, ensuring maximum audio signal purity. The analog and digital power supplies are also separate, further reducing the risk of crosstalk and noise.
FiiO K17: Various internal modules
FiiO K17: ACCUSILICON clocks
FiiO K17: Temporal accuracy and sound fidelity
The K17 uses three ultra-low-phase-noise crystal oscillators from ACCUSILICON, including the AS318-L (45.1584 MHz, 49.1520 MHz) and AS318-Pro (24.576 MHz) models. These components significantly reduce the impact of phase noise on audio signals, enabling faithful reproduction of PCM and DSD signals at various sampling rates. Thanks to this technology, the K17 ensures precise signal synchronization, which is crucial for high-resolution listening and a consistent sound experience.
FiiO K17: Significant computing power
The K17 is equipped with an X2000 multi-core processor, combining an XBurst2 main core and two logic cores, delivering high computing power while maintaining low power consumption. This processor is complemented by a dual-core ESP32-S3 SoC, capable of operating at up to 240MHz, ensuring a smooth and responsive user experience. The independent MS21586Q DSP, capable of 64-bit double-precision calculations at 360MHz, enables advanced audio processing, including 31-band parametric equalization (PEQ), without any loss of quality.
FiiO K17 : Processeurs
Fiio K17: A comprehensive range of connectivity options and unmatched versatility
The K17 stands out for its comprehensive connectivity: USB-C, USB-A, Toslink optical, and coaxial inputs, as well as balanced XLR and unbalanced RCA outputs. It supports high-resolution streaming (Wi-Fi/Ethernet with Roon Ready and AirPlay support), Bluetooth 5.1 (SBC, AAC, aptX, aptX HD, aptX LL, aptX Adaptive, LDAC), and can function as a preamplifier or external DAC. Its 3.93-inch color touchscreen and custom Android 12 interface make it easy to navigate and control features, while its aluminum chassis combines durability with a retro aesthetic.
Fiio K17: A stunning retro design and perfectly engineered ergonomics
With its compact dimensions (24.46 x 21.3 x 6.68 cm) and weight of 2.75 kg, the K17 is designed to fit seamlessly into an office or living room setting. Its design combines retro elegance with modernity, featuring physical controls and an intuitive touchscreen. The K17 also features advanced capabilities such as a 32-band equalizer, Roon and AirPlay compatibility, and a hi-fi preamp mode, making it an extremely versatile device.
FiiO K17 : Descriptive diagram
1Screen
2Menu button
3LED indicators
4Volume button
5ON/OFF LED indicator
6ON/OFF switch
7Output switch
8Gain switch
9USB-C input
10Single-ended Jack 6.35mm headphone output
11Balanced Jack 4.4mm headphone output
12Balanced XLR 4 pins headphone output
13Bluetooth / WiFi antenna
14Optical input
15Optical output
16Reset button
17Grounding switch
1812V trigger input
19RS232 port
20USB-C input
21USB-A (USB Host) input
22Ethernet RJ45 port
23Grounding terminal
24Coaxial input
25Coaxial output
26Balanced Jack 4.4mm line input
27Single-ended RCA line input
28Single-ended RCA line output
29Balanced XLR line output
30Power supply input
Product typeDAC
Headphone amplifier
Inputs1x Balanced Jack 4.4mm line input
1x Single-ended RCA line input
2x USB-C
1x Optical Toslink
1x Coaxial
1x USB-A (USB Host)
1x Ethernet RJ45
Trigger inputYes, Jack 3.5mm, 12V
Port RS232USB-C, for firmware updates and DSP configuration
Outputs1x Single-ended RCA line output
1x Balanced XLR line output
1x Single-ended Jack 6.35mm headphone output
1x Balanced Jack 4.4mm headphone output
1x Balanced XLR 4 pins headphone output
1x Optical Toslink
1x Coaxial
ConnectivityWiFi 2.4G/5G double bande
Ethernet RJ45
Bluetooth 5.1
Supported network protocolsRoon Ready
AirPlay
SoCX2000
MCUESP32-S3
DACAK4191EX
2x AK4499EQ
USB chipXMOS XU316
Bluetooth chipQCC5125
Headphone amplificationTransistors MJE243G/253G
TouchscreenLCD 3.96" (240*1020)
Supported sampling ratesUSB: PCM up to 32bit 768kHz, DSD Natif up to DSD512
Coaxial input: PCM up to 24bit 192kHz, DSD64
Optical input PCM up to 24bit 96kHz
Coaxial output: PCM up to 24bit 192kHz, DSD64
Optical output: PCM up to 24bit 192kHz
Streaming: PCM up to 32bit 384kHz, DSD DoP up to DSD256
Local playback: PCM up to 32bit 384kHz, DSD up to DSD256
MQA supportYes
Supported Bluetooth codecsSBC, AAC, aptX, aptX HD, aptX LL, aptX Adaptive, LDAC
Gain levelsUltra-High Gain Mode
Super-High Gain Mode
High-gain mode
Medium gain mode
Low-gain mode
PEQ31 bands
Control appFiiO Control
Adaptive impedancePO: 8~150Ω
BAL: 8~350Ω
Headphone output parameters (Jack 6.35mm, USB DAC/coaxial/Optical decoding, ultra-high gain mode)
Output power2x 1800mW @ 16Ω, THD+N <1%
2x 1850mW @ 32Ω, THD+N <1%
2x 240mW @ 300Ω, THD+N <1%
Noise floor< 5µV (A-weighted)
Frequency response20Hz~20kHz: attenuation < 0.05dB
20Hz~90kHz : attenuation < 3dB
Output impedance< 1Ω (32Ω)
Crosstalk≥ 76dB (1kHz @ 32Ω)
THD+N< 0.0005% (1kHz / -12dB @ 32Ω)
SNR≥ 124dB (A-weighted)
Voltage output (peak)> 24Vp-p
Headphone output parameters (Jack 6.35mm, USB DAC/coaxial/Optical decoding, super-high gain mode)
2x 1000mW @ 32Ω, THD+N <1%
2x 120mW @ 300Ω, THD+N <1%
THD+N< 0.00056% (1kHz / -9dB @ 32Ω)
SNR≥ 121dB (A-weighted)
Voltage output (peak)> 17Vp-p
Headphone output parameters (Jack 4.4mm/XLR4, USB DAC/coaxial/Optical decoding, ultra-high gain mode)
2x 4000mW @ 32Ω, THD+N <1%
2x 950mW @ 300Ω, THD+N <1%
Noise floor< 7.9µV (A-weighted)
Output impedance< 1.5Ω (32Ω)
Crosstalk≥ 119dB (1kHz @ 32Ω)
THD+N< 0.00049% (1kHz / -13dB @ 32Ω)
Voltage output (peak)> 48Vp-p
Headphone output parameters (Jack 4.4mm/XLR4, USB DAC/coaxial/optical decoding, super-high gain mode)
2x 3900mW @ 32Ω, THD+N <1%
2x 480mW @ 300Ω, THD+N <1%
THD+N< 0.00054% (1kHz / -10dB @ 32Ω)
SNR≥ 123dB (A-weighted)
Voltage output (peak)> 34Vp-p
Single-ended line output parameters (RCA, USB DAC/coaxial/optical decoding)
Noise floor< 2.2µV (A-weighted)
Crosstalk≥ 118dB (1kHz @ 10kΩ)
THD+N< 0.00053% (1kHz / -10dB @ 10kΩ)
Line out level2.5Vrms (1kHz @ 10kΩ)
Balanced line output parameters (XLR, USB DAC/coaxial/optical decoding)
Noise floor< 2.6µV (A-weighted)
Crosstalk≥ 121dB (1kHz @ 10kΩ)
THD+N< 0.00045% (1kHz / -10dB @ 10kΩ)
SNR≥ 125dB (A-weighted)
Line out level5Vrms (1kHz @ 10kΩ)
Supply voltageAC 100-120V/220-240V ~50/60Hz
Dimensions244.6 x 213 x 66.8mm
Weight2.75kg
Package1x FiiO K17
1x Power cable
1x Remote control
1x XLR4 connector cap
1x Fuse
2x USB cable
1x Jack 6.35mm adapter
InputWiFi
InputRS-232
InputRJ45
InputJack 4.4mm
OutputJack 6.35mm
OutputCoaxial SPDIF
OutputJack 4.4mm
OutputOptical Toslink
DAC / ADC ChipAK4499
Max sampling rate768kHz
Max sampling rateDSD512
ClassN/A
NetworkingYes
Remote ControlControl app
Remote ControlYes
FIIO K17 DAC Headphone Amplifier 2x AK4499EQ WiFi Roon AirPlay Bluetooth 5.4 aptX LDAC 32bit 768kHz DSD512 Black
The FiiO K17 is a high-end DAC and headphone amplifier designed to deliver a comprehensive and versatile audio experience, whether for audiophiles...
