IFI AUDIO SILENT POWER PULSAR USB USB-C Filter
New
The iFi Audio Pulsar USB is a USB filter designed to isolate the source from the audio system and limit the transmission of electrical interference through the digital link. Its galvanic isolation physically separates the two devices, reducing noise caused by ground potential differences and radio frequency interference (RFI). Audio data can then be transmitted without these electrical disturbances following the same path to the DAC.
Reference : 22713
249,00 €tax incl.
207,50 € tax excl.
iFi Audio Silent Power Pulsar USB USB-C Filter
IFI AUDIO SILENT POWER PULSAR USB: Front view
iFi Audio Pulsar USB: Active power supply noise reduction
A USB link carries both data and a 5V power supply, whose noise may originate from the source device's circuits. The Pulsar USB features Active Noise Cancellation (ANC) technology that targets the electromagnetic and radio frequency interference present on this line, generating an inverse signal designed to cancel it.
Unlike passive filtering, this approach acts on interference within the audible range. iFi claims a noise reduction of up to 40dB, with a power supply up to 100 times quieter than with standard filtering, in order to deliver a cleaner USB voltage to the DAC.
IFI AUDIO SILENT POWER PULSAR USB: ANC
IFI AUDIO SILENT POWER PULSAR USB: Cross-section view of the USB cable
iFi Audio Pulsar USB: Conductors and shielding
The internal design is based on high-purity OFHC copper conductors arranged in parallel to limit inductance and preserve signal integrity. Four layers of shielding surround the conductors to reduce exposure to external interference, while this architecture also aims to limit crosstalk between lines.
The Pulsar USB maintains an impedance of 90 ohms, with up to 15 times less variation than many high-end USB cables, according to iFi. This stability contributes to consistent transmission between the source and the DAC, without altering the original signal.
iFi Audio Pulsar USB: USB 3.1 data rate
USB 3.1 compatible, the Pulsar USB supports data rates of up to 10 Gbit/s, approximately 20 times the maximum speed of USB 2.0. This bandwidth handles high-resolution audio file transfers without the link's data rate becoming a limiting factor.
It can therefore be inserted between a USB source and a DAC in a setup dedicated to high-resolution file playback, combining galvanic isolation, power supply noise reduction and high-speed transmission.
IFI AUDIO SILENT POWER PULSAR USB: 10Gbps speed
Technical specifications
Product typeUSB filter
Inputs1x USB-C
Outputs1x USB-C
Output voltage5V/1.5A
Cable length1m
Transfer speed10Gbps
Conductor materialsOFC copper
Silver
InsulationPolyethylene
Shielding
Impedance90Ω (±1%)
Dimensions136 x 86 x 45mm
Weight187g
ColorGrey
Package1x iFi Audio Pulsar USB
1x USB-A to USB-C adapter
1x USB-B to USB-C adapter
OutputUSB
Max sampling rateNC
ColorGray
Interface chipNC
The iFi Audio Pulsar USB is a USB filter designed to isolate the source from the audio system and limit the transmission of electrical interference...
