DAC 2x ES9068AS I2S Bluetooth 5.0 32bit 768kHz DSD512 MQA
Loxjie offers with its D40 a powerful, versatile DAC, dressed in a sober and modern chassis. This one benefits from a double DAC ES9068AS chip, a complete connectivity, with Bluetooth wireless reception, and a neat general design, using many quality audio components.
At the heart of the D40 is an extremely efficient conversion stage, using two ESS ES9068AS DAC chips. These 32bit converters support high sampling rates up to PCM 32bit 768kHz and DSD512, and allow the decoding and reading of MQA files. It is also the assurance of a particularly precise and rich sound reproduction, with a THD+N of -122dB.
LMQA (Master Quality Authenticated) is an award-winning British technology that restores the sound of the original recording. The MQA Master file is authenticated by the artists, producers or rights holders. These files are light enough to stream or download. The D40 includes an MQA decoder to play these files for the best possible audio quality.
With its Qualcomm Bluetooth 5.0 receiver chip, the D40 enables remote music streaming directly from a smartphone or connected tablet. In addition, it supports the high-quality transmission codecs aptX, aptX-HD and LDAC.
The D40 incorporates a PLL and provides three filters. It is thus possible to adjust the filter according to the stability of the clock signal received at the input of the device, in order to improve the sound quality.
In order to adapt to the majority of devices with I2S connectivity, the D40 offers no less than 8 modes to adapt the HDMI pinout and therefore the type of I2S interface.
The whole architecture and internal design of the D40 benefits from high quality components adapted to audio. In addition to the two ES9068AS DAC chips, we find a XMOS XU216 USB interface, two ultra-low distortion OPA1612 AOPs and a totally optimized power supply. This set, perfectly integrated, participates greatly in the quality of sound restitution of the D40.
1 | ON/OFF |
2 | Filter selection |
3 | Input selection |
4 | Output selection |
5 | Screen |
6 | Multifunction knob |
7 | Jack 6.35mm headphone output |
8 | RCA Output |
9 | XLR Output |
10 | AES/EBU Input |
11 | Bluetooth antenna |
12 | I2S Input |
13 | Optical input |
14 | Coaxial input |
15 | USB input |
16 | Power connector |
" Playing at this level of performance is not easy: tons of attention needs to be paid to circuit design and layout to stomp any and all sources of noise and distortion. Other than leaving some ESS IMD distortion on the table, the D40 performs superbly in DAC department. The headphone output while not at the same level, still provides excellent performance and volume level."
Product type | DAC |
DAC Chip | ESS ES9068AS |
Inputs | 1x USB-B 1x Optical Toslink 1x Coaxial 1x I2S via HDMI 1x AES/EBU Bluetooth |
Outputs | 1x Single-ended stereo RCA 1x Balanced stereo XLR 1x Jack 6.35mm headphone output |
THD+N | 0.00008% (-122dB) |
Dynamic range | RCA : 125dB XLR : 128dB |
SNR | RCA : 125dB XLR : 128dB |
Supported Bluetooth codecs | AAC, SBC, aptX, aptX-HD, LDAC |
USB transmission | Asynchronous |
USB compatibility | Windows 7/8/8.1/10/11 Mac OSX Linux |
Supported sampling rates | USB/I2S : PCM up to 32bit 768kHz, DSD up to DSD512 Optical/Coaxial/AES : PCM up to 24bit 192kHz, DSD DoP up to DSD64 |
Output impedance | 100Ω |
Output level | XLR : 4Vrms RCA : 2Vrms |
Dimensions | 240 x 195 x 43mm |
Consumption | 5W |
Weight | 1.1kg |
Housing material | Aluminum |
Color | Gray |
Input | USB |
Input | Optical |
Input | I2S via HDMI |
Input | SPDIF |
Input | Bluetooth |
Input | AES/EBU |
Output | XLR |
Output | RCA |
Output | Jack 6.35mm |
DAC / ADC Chip | ES9068AS |
Max sampling rate | DSD512 |
Max sampling rate | 768kHz |
Color | Gray |
Networking | No |
Remote Control | Yes |
