By buying this product you get 65 loyalty points
32Bit/384kHz DAC DSD DXD & Headphone amplifier
.jpg)
After about a year of waiting, Matrix launches its "S" model which joins the range of Mini-I DAC's. With the same design as the Mini-I Pro 2, it brings a real power boost based on an ES9026PRO converter. This means that the excellent performances already achieved by the Mini-I Pro 1 of the name or by the DAC of the Mini-I series in general can be extended even further.
The brand new 8-channel ES9026Pro converter provides great optimization of the integrated DSP compared to its predecessor, the ES9016S, while providing a better user experience.
Instead of limiting DSD support only via the USB port, Matrix allows you to take advantage of a full DSD connection right now. Thus, the Mini-I Pro 2S supports DoP support via the Optical, Coaxial and AES/EBU inputs, allowing you to take advantage of the DoP function of your drives.
With more than 7 types of PCM digital filters, you can select a filter curve to refine the returned timbre. Thus, everyone can find a mode adapted to their listening needs.
The line output can be adjusted with a volume gain up to +18dB. In this way, it is no longer necessary to add an external pre-amplifier to use active low gain speakers. Of course, the Mini-I Pro 2S can work with a power amplifier for a more flexible use and more in accordance with your needs.
For easy and comfortable listening, the Matrix Mini-I Pro 2S lets you stream your files in Bluetooth. It therefore incorporates the aptX standard, which has the advantage of protecting your files from Bluetooth damage.
The Mini-I Pro 2S inherits the elegant design of the Mini-I series DACs. CNC-machined with anodized surface, it announces at a glance a quality product.
The DAC, supplied with a remote control, wins with this accessory a real plus in terms of ergonomics. This allows you to switch the unit on/off, control the volume or select the active source.
| Digital outputs | |
| AES | PCM 16-24Bit /44.1kHz, 48kHz, 88.2kHz, 96kHz, 176.4kHz, 192kHz DSD DSD64 (DoP) |
| Coaxial | PCM 16-24Bit /44.1kHz, 48kHz, 88.2kHz, 96kHz, 176.4kHz, 192kHz DSD DSD64 (DoP) |
| Optique | PCM 16-24Bit /44.1kHz, 48kHz, 88.2kHz, 96kHz, 176.4kHz, 192kHz DSD DSD64 (DoP) |
| USB | PCM 16-32Bit /44.1kHz, 48kHz, 88.2kHz, 96kHz, 176.4kHz, 192kHz, 352.8kHz, 384kHz DSD DSD64/DSD128 (DoP) DSD64/DSD128/DSD256 (ASIO Native) |
| Bluetooth | PCM 16Bit/48kHz aptX/AAC/SBC |
| Version Bluetooth | 4.0 |
| Bluetooth frequency band | 2.402GHz - 2.480GHz |
| Bluetooth Power | Class II |
| Bluetooth max. operating distance | 10-15m |
| Delay | <20ms |
| Analog outputs | |
| XLR | SNR : > -123dB 20Hz-20kHz A-Weighting THD+N : <0.0003% @ 1kHz A-Weighting Réponse en fréquence : 20Hz - 20kHz (+0.01dB/-0.02dB) Diaphonie : > -130dB @ 1kHz Sortie XLR : 4Vrms fixe at 0dBFS Mode DAC / 0-4Vrms ajustable at 0dBFS Mode Preamp |
| RCA | SNR : > -120dB 20Hz-20kHz A-Weighting THD+N : < 0.0005% @ 1kHz A-Weighting Réponse en fréquence : 20Hz - 20kHz (+0.01dB/-0.02dB) Diaphonie : > -126dB @ 1kHz Sortie RCA : 2Vrms fixe at 0dBFS Mode DAC / 0-2Vrms ajustable at 0dBFS Mode Preamp |
| Headphone output | |
| SNR | >-116dB 20Hz-20kHz A-Weighting |
| THD+N | <0.0007% @ 1kHz A-Weighting à 300ohms 25mW |
| Réponse en fréquence | 20Hz-20kHz (+0dB/-0.1dB) |
| Diaphonie | >-126dB @1kHz |
| Impédance sortie casque | 10 Ohms |
| Puissance sortie casque | 820mW @ 33ohms at THD+N=0.1% 210mW @ 300ohms at THD+N=0.1% 110mW @ 600ohms at THD+N=0.1% |
| General | |
| Compatibility | Windows 7/8/8.1/10 (driver required) Mac OS X10.6.4 and later versions Most of the Android devices can be used with OTG cable iOS devices can be used with Camera Kit |
| Power voltage | 230V position is fit for AC220V-240V 50/60Hz 115V position is fit for AC100V-120V 50/60Hz |
| Power Consumption | < 10W |
| Dimensions | 168 x 205 x 47mm |
| Weight | 1.3kg |
| Accessories | 1x Quick Start Guide 1x RM2 Remote Control 1x Bluetooth Antenna 1x Power Cord 1x USB Cable |
| Input | Bluetooth |
| Input | XLR |
| Input | Optical |
| Input | SPDIF |
| Output | XLR |
| Output | RCA |
| DAC / ADC Chip | ES9026PRO |
| Max sampling rate | DSD256 |
| Max sampling rate | 384kHz |
| Color | Silver |
| Networking | No |
| Remote Control | Yes |
