SMSL C200 PRO DAC / Headphone Amplifier
The SMSL C200 Pro is a versatile, high-performance DAC / headphone amplifier based on market-renowned audiophile components. It incorporates an ES9039Q2M DAC chip, an XMOS XU316 USB interface and no fewer than four OPA1612A OPAs. This enables it to support high-definition sampling rates up to PCM 32bit 768kHz and DSD512, while delivering headphone output power of up to 2x1.5W into 32 ohms.
Reference : 20622
199,00 €tax incl.
165,83 € tax excl.
Shipping date: 24-06-2026.
SMSL C200 Pro DAC Headphone Amplifier ES9039Q2M XMOS XU316 Bluetooth 5.1 32bit 768kHz DSD512
Photo of SMSL C200 PRO
The SMSL C200 Pro is a versatile, high-performance DAC / headphone amplifier based on market-renowned audiophile components. It incorporates an ES9039Q2M DAC chip, an XMOS XU316 USB interface and no fewer than four OPA1612A OPAs. This enables it to support high-definition sampling rates up to PCM 32bit 768kHz and DSD512, while delivering headphone output power of up to 2x1.5W into 32 ohms. Added to this is Bluetooth 5.1 functionality, enabling it to handle high-definition codecs such as aptX, aptX-HD and LDAC. On the connectivity side, there are a number of digital inputs, USB-C, Toslink optical and coaxial, while on the output side, there's a single-ended RCA output and a balanced TRS jack output. There are also two headphone outputs on the front panel: single-ended 6.35mm jack and balanced 4.4mm jack. As for the appearance and aesthetics of the SMSL C200 Pro, the brand has opted for simplicity and elegance, while integrating a small display.
SMSL C200 PRO highlights
SMSL C200 Pro: a high-performance chipset
The XMOS XU316 USB interface enables the SMSL C200 PRO to support sampling rates up to PCM 32bit 768kHz and DSD512.
DAC ES9039Q2M
DAC ES9039Q2M
The ES9039Q2M DAC chip not only handles high-resolution sampling rates, but also offers exceptional performance, with a dynamic range of up to 130dB, low THD of -126dB and THD+N of -120dB.
SMSL C200 Pro: Bluetooth 5.1
Thanks to a Qualcomm Bluetooth receiver chip, the SMSL C200 Pro supports high-definition codecs for the most reliable and stable wireless connection: SBC, AAC, aptX, aptX-HD and LDAC (24bit 96kHz).
SMSL C200 PRO Bluetooth function
SMSL C200 Pro: a powerful headphones amplifier
No fewer than four OPA OPA1612A amplifiers are used to amplify the single-ended 6.35mm jack and balanced 4.4mm jack headphone outputs, giving the SMSL C200 Pro the ability to drive a wide range of headphones and earphones, including high-impedance models.
Headphones amplification power2x 3W @ 16 ohm
2x 1.5W @ 32 ohm
2x 350mW @ 150 ohm
2x 170mW @ 300 ohm
2x 85mW @ 600 ohm
Headphone amplifier gain+9.5dB
SMSL C200 PRO headphone output power
SMSL C200 Pro overview
SMSL C200 PRO overview
1Single-ended 6.35mm jack headphone output
2Balanced 4.4mm jack headphone output
3Multifunction button
4IR receiver
5Display
6Power supply
7Bluetooth antenna
8Optical Toslink input
9USB-C input
10Coaxial input
11Single-ended RCA output
12Balanced 6.35mm TRS jack output
Product typeDAC / Headphone amplifier
DAC chipES9039Q2M
USB interfaceXMOS XU316
OPA4x OPA1612A
Inputs1x USB-C
1x Optical Toslink
1x Coaxial
Bluetooth
1x Balanced stereo 6.35mm TRS jack
1x Single-ended 6.35mm headphone output
1x Balanced 4.4mm headphone output
Supported sampling ratesUSB: PCM up to 32bit 768kHz, DSD up to DSD512
Toslink optical and coaxial: PCM up to 24bit 192kHz, DSD DoP64
Bluetooth version5.1
Supported Bluetooth codecsAAC, SBC, aptX, aptX-HD, LDAC
Max. variable output levelSingle-ended RCA : 2.5Vrms
Balanced Jack TRS : 5Vrms
Headphone output power2x 3W @ 16 ohm
2x 1.5W @ 32 ohm
2x 350mW @ 150 ohm
2x 170mW @ 300 ohm
2x 85mW @ 600 ohm
Headphone output gain+9.5dB
THD+NLine output: 0.00006% (-123.5dB)
Headphone output: 0.00009% (-120dB)
Dynamic rangeRCA: 126dB
Jack 6.35mm TRS: 129dB
Headphone amp: 125dB
SNRRCA: 126dB
Output impedanceLine output: 100 ohm
Headphone output: near 0 ohm
USB transmissionUSB 1.1 and USB 2.0 (asynchronous)
USB compatibilityWindows 7/8/8.1/10/11 (with driver)
MAC OS, Linux, IOS, Android (without driver)
Power supply100-240V AC
Dimensions139 x 147.5 x 32mm
Weight510g
Package1x SMSL C200 Pro
1x IR remote control
1x Bluetooth antenna
1x USB-A to USB-C cable
1x Power supply cable
OutputJack 6.35mm
OutputJack 4.4mm
DAC / ADC ChipES9039Q2M
Max sampling rate768kHz
Max sampling rateDSD512
ClassClass A / AB
Remote ControlYes
SMSL C200 PRO DAC Headphone Amplifier ES9039Q2M XMOS XU316 Bluetooth 5.1 32bit 768kHz DSD512
The SMSL C200 Pro is a versatile, high-performance DAC / headphone amplifier based on market-renowned audiophile components. It incorporates an...
