DAC AK4493S XMOS XU316 Bluetooth 5.0 32bit 768kHz DSD512 MQA
The SMSL D12 is a compact and performant DAC, using an AKM AK4493S digital to analog conversion chip to provide dynamic, musical and accurate sound. This one, in association with a modern USB interface XMOS XU316, also allows the support of high resolution audio streams up to PCM 32bit 768kHz, DSD512, as well as the decoding of MQA files. On the connectivity side, the D12 is simple and efficient with USB-C input and Bluetooth 5.0 wireless connectivity. The output is done in RCA or via the headphone output 6.35mm on the front.
Product type | DAC |
Inputs | Bluetooth 5.0 1* USB |
Outputs | 1* Stereo RCA 1* Jack 6.35mm headphone output |
DAC chip | AKM AK4493S |
USB interface | XMOS XU316 |
Output level | 2.3Vrms |
Gain | +2.5dB |
Output power | 400mW @ 16Ω 300mW @ 32Ω |
THD+N | 0.00015% (-116dB) |
Dynamic range | 120dB |
SNR | 120dB |
USB compatibility | Windows 7 / 8 / 8.1 / 10 / 11 Mac OSX10.6 ou ultérieur Linux Android iOS Sony PS5 (UAC1) Nintendo Switch (UAC1) |
Supported sampling rates | PCM up to 32bit 768kHz DSD up to DSD512 |
Supply voltage | 5VDC via USB-C |
Consumption | < 10W |
Standby consumption | < 0.5W |
Dimensions (L*P*H) | 139*102.5*33mm |
Weight | 355g |
Color | Black |
Package | 1* SMSL D12 1* Remote control 1* Antenna 2USB-C to USB-A cable |
