SMSL DS100 DAC CS43131 Headphone amplifier
LSMSL's DS100 is a compact, high-performance DAC that can also act as a headphone amplifier. With its well-designed construction, it offers great versatility and high-quality sound reproduction.
Reference : 19260
99,00 €tax incl.
82,50 € tax excl.
SMSL DS100 DAC CS43131 Headphone amplifier XU316 32bit 768kHz DSD512 MQA MQA-CD
SMSL DS100 DAC CS43131 Headphone amplifier XU316 32bit 768kHz DSD512 MQA MQA-CD: Front view
SMSL DS100 : Cirrus Logic CS43131 Chip
SMSL's DS100 is based on Cirrus Logic's CS43131 chip. In addition to high-quality digital/analogue conversion, this chip offers an output of 2 Vrms for 600 Ω high-impedance headphones with >110 dB inter-channel isolation, and 30 mW for 32 Ω low-impedance headphones. Thanks to this Cirrus Logic chip, the DS100 is capable of driving a wide range of headphones.
SMSL DS100 : Cirrus Logic CS43131 chip
SMSL DS100 : Xmos XU316 chip
SMSL DS100 : Xmos XU316 USB interface
The DS100's USB-C input is paired with a high-performance XMOS XU316 interface, which efficiently processes the audio signal received. In conjunction with the CS43131 DAC, it enables the SMSL DS100 to support high-resolution audio signals up to PCM 32bit 768kHz and DSD512.
SMSL DS100 : MQA and MQA-CD
The DS100 also incorporates an MQA (Master Quality Authenticated) decoder. This format offers very high sound quality, as close as possible to studio recording, with each file authenticated by the artist, producer or copyright holder. SMSL's DAC also supports MQA-CD.
SMSL DS100 : numbered diagram
16.35 mm Jack headphone output
24.4 mm Jack headphone output
3MQA indicator
4Headphone amplification indicator
5Coaxial indicator
6Optical indicator
7USB indicator
8Volume knob
9USB-C input
10Toslink optical input
11Coaxial input
12Stereo RCA output
Product typeDAC / Headphone amplifier
DAC / amplification chipCirrus Logic CS43131
Inputs1x USB-C
1x Optical Toslink
1x Coaxial
Outputs1x Headphone output 6.35 mm Jack
1x Headphone output 4.4 mm Jack
1x Stereo RCA
Output level2Vrms
Total harmonic distortion (THD)0.00017%
Signal-to-noise ratio127dB
Dynamic range127dB
USB CompatibilityWindows 7/8/8.1/10/11 (driver needed)
Mac OSX 10.6+
Linux
Android
Supported sampling ratesUSB : PCM up to 32bit 768kHz, Native DSD up to DSD512, MQA, DoP 256
Optique / Coaxial : PCM up to 24bit 192kHz, MQA, DoP 64
Consumption<1W
Standby consumption<0.1W
Dimensions101 x 89 x 30mm
Weight180g
Package1x SMSL DS100
1x USB-C to USB-A Cable
OutputJack 4.4mm
OutputJack 6.35mm
DAC / ADC ChipCS43131
Max sampling rate768kHz
Max sampling rateDSD512
Max sampling rateMQA
LSMSL's DS100 is a compact, high-performance DAC that can also act as a headphone amplifier. With its well-designed construction, it offers...
