SMSL R1 DAC Headphone Amplifier Black
New
The SMSL R1 is a high-performance headphone amplifier DAC with a unique look. It uses an ES9018K2M DAC chips for high-quality digital-to-analog conversion. It also offers several additional features, such as four equalization modes and bass and treble controls, allowing you to tailor the sound to your preferences.
Reference : 21179
74,90 €tax incl.
62,42 € tax excl.
SMSL R1 DAC Headphone Amplifier ES9018K2M 32bit 768kHz DSD512 Black
Photo du SMSL R1
The SMSL R1 is a high-performance headphone amplifier and DAC with a unique look. It uses an ES9018K2M DAC chip for high-quality digital-to-analog conversion. It also offers several additional features, such as four equalization modes and bass and treble controls, allowing you to tailor the sound to your preferences. In terms of connectivity, it is not to be outdone, with several digital inputs (USB-C, Toslink optical, SPDIF coaxial), as well as an RCA line output and two headphone outputs: 3.5mm single-ended jack and 4.4mm balanced jack. This set of connections is completed by a 3.5mm MIC input, perfect for a gaming setup. Specially designed for headphone listening, the SMSL R1 has an output power of up to 500mW under 32 ohms.
Les avantages du SMSL R1
SMSL R1: A high-performance DAC amplifier
The ES9018K2M DAC chip inside the SMSL R1 enable it to perform high-quality digital-to-analog conversion. In addition, its amplifier stage allows it to drive IEMs or headphones with an impedance of 32 to 600 ohms. In fact, it delivers up to 120mW under 32Ω.
Photo de l'intérieur du SMSL R1
EQ et réglage des tonalités du SMSL R1
SMSL R1: EQ and tone control
Additional features such as 4 equalization modes allow you to sculpt the sound. Three faders also allow you to adjust the microphone volume or bass and treble tones from -9dB to +9dB.
SMSL R1: A retro design
On the front panel, there are three faders, an input level indicator, and a vintage potentiometer for headphone volume control. All of these elements combine to create a sleek, retro look that SMSL R1 users are sure to love.
Le design du SMSL R1
SMSL R1 overview
Aperçu du SMSL R1
1Input level indicator
2Microphone volume
3Treble
4Bass
5EQ adjustment
6Power on / input selection
7Headphone output volume control
8RCA line output (1.5Vrms)
9Coaxial input
10optical input
11USB-C input
125V USB-C power port
13Microphone input
143.5mm single-ended headphone output
154.4mm balanced headphone output
Product typeDAC and headphone amplifier
DACES9018K2M
USB interfaceXMOS XU316
Inputs1x USB-C
1x Toslink optical
1x Coaxial
Outputs1x 3.5mm single-ended headphone jack output
1x 4.4mm balanced headphone jack output
1x RCA line output
Other connectors1x 3.5mm microphone jack
Supported sample ratesPCM 32bit 768kHz, DSD512
Line output level1.5Vrms
THD+N (non-weighted)0.009% (-80dB)
Dynamic range (non-weighted)98dB
SNR (non-weighted)98dB
Channel separation95dB
Headphone impedance32 ohms
Headphone output power120mW @ 32 ohms
Bass and treble adjustment-9dB/+9dB
Power supply5V via USB-C
Dimensions76 x 34.6 x 143.8mm
Weight316.4g
Package1x SMSL R1
1x 3.5mm headphone microphone splitter cable
1x USB-C/A to USB-C cable
OutputJack 3.5mm
OutputJack 4.4mm
DAC / ADC ChipES9018K2M
Max sampling rateNC
ClassN/A
The SMSL R1 is a high-performance headphone amplifier DAC with a unique look. It uses an ES9018K2M DAC chips for high-quality digital-to-analog...
