TOPPING D90 Balanced DAC AK4499 XMOS XU208 I2S 32bit 768kHz DSD512 Bluetooth 5.0 Black
A direct successor to the D70 Topping, the D90 benefits from the same refinements as its big brother while updating its DAC with a newer and more efficient version, the AK4499 AKM. For the rest, it largely follows the excellent internal design of the previous model and its exceptional performance.
By buying this product you get 74 loyalty points
Reference : 14281
749,00 €tax incl.
624,17 € tax excl.
Topping D90
Balanced DAC AK4499 XMOS XU208 I2S 32bit 768kHz DSD512 Black
Topping D90 DAC Symétrique AK4499 XMOS XU208 I2S 32bit 768kHz DSD512 Noir
AK4499 AKM
DAC AK4499 & Accusilicon Clocks
New flagship from AKM, the AK4499 DAC chip allows precise, fast and clean conversion of high-resolution audio files. The D90 thus integrates on its digital-to-analog conversion stage an AK4499 chip with Thesycon drivers allowing transparent and rich sound reproduction and supporting PCM files up to 32bit 768kHz and DSD up to DSD512 (via USB and I2S).
The DAC is combined with a pair of AccuSilicon 451584MHz and 49.1520MHz high-end femtosecond clocks and a CPLD. These allow a perfect synchronization of the data signals for an absolutely impressive jitter attenuation.
AK4499 AKM
Connectivity & Features
With its many features and connections, the D90 can be integrated into a vast majority of audio systems, offering many options for use and installation.
For its input connectivity, there are AES, USB-B (XMOS), Coaxial, Toslink Optics, and I2S LVDS via HDMI. Note that this last input has several selectable modes to adapt to your other I2S LVDS devices. On the output side, the D90 offers unbalanced RCA Stereo and balanced XLR. The D90's intelligent design allows only one or both outputs to be activated at a time.
With its integrated volume control, the D90 also acts as a preamplifier since it includes a volume controller. This volume control function can however be disabled so that the D90 can only be used as a DAC with output levels constantly at their maximums, i.e. 4Vrms for XLR output and 2Vrms for RCA output.
USB XMOS XU208 Interface & SPDIF AK4118 Receiver
For its digital interfaces, Topping once again chooses very high quality and performance by integrating into its D90 an XMOS XU208 USB chip supporting high sampling rates up to 32bit 768kHz and up to native DSD512.
For SPDIF streams, an AKM AK4118 AKM chip processes the signal with extremely low jitter. This last chip is used for the Optical, Coaxial and AES inputs and allows sampling rates up to 24bit 192kHz PCM to be achieved on the latter.
Topping D90 measurements by Audio Science Review
Mesures du Topping D90 par Audio Science Review
Product typeDAC
DAC ChipAKM AK4499
USB InterfaceXMOS XU208
SPDIF InterfaceAK4118
Bluetooth5.0 / Apt-X HD / LDAC
Inputs1x I2S LVDS (HDMI)
1x USB-B (XMOS)
1x Optical Toslink
1x Coaxial SPDIF
1x AES/EBU
Outputs1x Balanced XLR
1x Single-ended RCA
Supported sampling ratesUSB : PCM up to 32bit 768kHz / Native DSD up to DSD512 / DSD DoP up to DSD256
I2S : PCM up to 32bit 768kHz / DSD up to DSD512
Coaxial, Optical, AES : PCM up to 24bit 192kHz
Output voltageRCA : 2Vrms @ 0dBFS
XLR : 4Vrms @ 0dBFS
Dynamic range (A-Weighting)128dB
Power supplyAC 110V/220V 50/60Hz (switchable) via IEC (cable included)
Case materialAluminium
IncluedUSB-B to USB-A cable / Power cable / Remote control
InputHDMI
InputAES/EBU
DAC / ADC ChipAK4499
Max sampling rate768kHz
Max sampling rateDSD512
Remote ControlYes
5 reviews
End game DAC
i dont usually say end game . but topping D90 could be the end game dac for many.
I'm uppgrading from Asus essence one. Topping D90 has much clear sound, sound stage is much more. deeper bass and tight bass.
I live in Sweden and I'm happy to say that audiophonics has very good service and delivery.
 (3)
This review has been posted for TOPPING D90 Balanced DAC AK4499 XMOS XU208 I2S 32bit 768kHz DSD512 Bluetooth 5.0 Black
Compact Gem
This is a very good DAC and significant step-up from my previous DAC. The sound is very clear, detailed and has good dynamics and bass extension, but it will show-up any flaws in your streamer. USB and S/PDIF inputs are both very good. I have not tried I2S and AES inputs or AES output yet.
Satisfait, un gain significatif,
Bonjour, d'abord bravo à l'equide d'Audiophonics, qui m'ont envoyé le produit aussi rapidement, sachant qu'on est sous confinement, le DAC est utilisé comme dac pure sur un streamer attol 200 "son agressif"et préamp attol pr 300 qui est équipé d'une puce AKM =4490, ampli Marantz mm 7025 et enceintes Chorus 836, je peux dire que j'ai un gain significatif en qualité sonore, plus de profondeur dans les graves, le medium reste relativement neutre pour mes enceintes, y compris dans le haut medium"maillon faible de mes enceintes" transparence, le timbre et qualité des aigues très appréciés, bref je ne regrète pas mon achat, ah oui pour l'instant j'utilise l'entrée coaxal et sortie RCA, je n'ai pas branché encore avec la sortie XLR directement sur l'ampli Marantz, d'ailleur je demande si quelqu'un peux me conseiller sur un cable XLR qui va avec la gamme de mon matériel. Je reste disponible pour partager ma modeste expérience .
Excellent dac
j'ai acheté ce dac en remplacement d'un AKM4490 et franchement je ne pensais pas que le gap serait aussi important : beaucoup plus d'information dans ce qu'on appelle généralement le haut médium, la scène sonore est encore plus réelle avec plus de matière et sur les bons enregistrements,
on a l'impression d'y être,,,,,
Best Dac Ever
Tested in Spdif and Usb connection..excellent
 (4)
A direct successor to the D70 Topping, the D90 benefits from the same refinements as its big brother while updating its DAC with a newer and more...
