TOPPING D900 Discrete DAC
New
The Topping D900 pushes the boundaries of audio fidelity with an exclusive 32-phase DSM (Discrete Sigma Modulation) architecture. A true showcase of Topping's technological know-how, this top-of-the-range DAC combines digital precision, organic musicality and total flexibility to sublimate all your sources. It supports high-resolution sampling rates up to PCM 32bit 768kHz and DSD512.
By buying this product you get 179 loyalty points
Reference : 20876
1 790,00 €tax incl.
1 491,67 € tax excl.
Topping D900 Discrete 1bit DAC Bluetooth 5.1 LDAC 32bit 768kHz DSD512
Photo of Topping D900
The Topping D900 pushes the boundaries of audio fidelity with an exclusive 32-phase DSM (Discrete Sigma Modulation) architecture. A true showcase of Topping's technological know-how, this top-of-the-range DAC combines digital precision, organic musicality and total flexibility to sublimate all your sources. It supports high-resolution sampling rates up to PCM 32bit 768kHz and DSD512. Its digital-to-analog conversion stage is supported by an Altera Max II CPLD and Accusilicon 45MHz/49MHz clocks. Numerous features are available, such as Bluetooth 5.1 supporting LDAC, and a 10-band parametric equalizer accessible via the “Topping Tune” application. When it comes to connectivity, the D900 is well equipped with digital inputs for a wide range of configurations, while its outputs include two balanced XLR outputs: a line output and a preamp output.
Topping D900 highlights
Topping D900: A discrete digital-to-analog conversion stage
The D900 is based on a 1bit PSRM discrete digital-to-analog conversion module. This circuit preserves the integrity of the signal while the DAC is working, enabling it to offer exceptional performance, with THD+N below -140dB and SNR of 131dB. This Topping DAC also incorporates a new I/V conversion circuit for high dynamics and an immersive sound experience.
Topping D900 conversion range
Topping D900: 2" screen with Aurora UI
On the front of the D900 is a beautiful color screen, powered by Topping's Aurora UI interface, for the ultimate user experience. This interface allows you to display all the information on the current playback, easily navigate through the device's parameters, and display an FFT spectrum or various vumeters. Added to this is a premium-quality, aluminum-bodied remote control.
The Topping D900 screen
Bluetooth functionality of the Topping D900
Topping D900 : Bluetooth 5.1 LDAC
In terms of connectivity, Topping has chosen to integrate a latest-generation Qualcomm QCC5125 Bluetooth receiver chip. As a result, the D900 supports high-resolution Bluetooth transmission codecs SBC, AAC, aptX, aptX-HD, aptX-Adaptive and LDAC. LDAC 24bit 96kHz, superior to standard CD quality, offers a reliable, stable and pleasant listening experience.
Topping D900: 10-band parametric equalizer
In addition to its many features, the D900 benefits from a new 10-band parametric equalizer for highly precise adjustment of frequencies and gain. This adjustment software offers the possibility of fully personalized rendering by the user.
Topping Tune will be available on MAC OS in the second half of 2025. It is currently only available for Windows.
Topping D900 equalizer
Topping D900 overview
Overview of the Topping D900
1Screen
2Volume control / multi-function button
3XLR preamp output
4XLR line output
5I2S input via HDMI
6AES/EBU input
72x Toslink optical input
82x Coaxial input
9Bluetooth antenna
10USB-B input
11USB-C input
12In/Out trigger
13IEC input / Power switch
I2S connection via HDMI
Product typeDAC
DAC chipPSRM circuit
Bluetooth chipQCC5125
CPLDAltera Max II
Inputs1x USB-C
1x USB-B
2x Coaxial
2x Toslink optical
1x AES/EBU
1x I2S via HDMI
Bluetooth
Outputs1x XLR line output
1x XLR preamp output
Supported sample ratesPCM up to 32Bit 768kHz
DSD up to DSD512
Bluetooth version5.1
Supported Bluetooth codecsSBC, AAC, aptX, aptX-HD, aptX-Adaptive and LDAC
In/Out trigger
DAC + Preamplifier function
10-band equalization
Color display
InterfaceAurora UI
XLR line output specifications
THD+N @ A-WT< 0.000055% @ 1kHz
THD @ No-wt 45kBw< 0.00015% @ 20-20kHz
SNR @ A-WT131dB @ 1kHz
Dynamic range @ A-WT131dB @ 1kHz
Frequency response20Hz-20kHz (+/-0.3dB)
20Hz-40kHz (+/-1.0dB)
Output level4.2Vrms @ 0dBFS (4V mode)
5.2Vrms @ 0dBFS (5V mode)
Noise @ A-WT< 1.5uVrms
Channel crosstalk-147dB @ 1kHz
Channel balance0.3dB
Output impedance100 ohms
XLR preamp output specifications
20Hz-40kHz (+/-0.1dB)
Output level10.5Vrms @ 0dBFS (4V mode)
13Vrms @ 0dBFS (5V mode)
Noise @ A-WT< 1.6Vrms
ColorSilver
Package1x Topping D900
1x Bluetooth remote control
1x Bluetooth antenna
1x Power cord
Topping D900 measurements
InputAES/EBU
InputI2S via HDMI
DAC / ADC ChipPSRM
Max sampling rateDSD512
Max sampling rate768kHz
ColorSilver
Remote ControlYes
TOPPING D900 Discrete 1bit DAC Bluetooth 5.1 LDAC 32bit 768kHz DSD512
The Topping D900 pushes the boundaries of audio fidelity with an exclusive 32-phase DSM (Discrete Sigma Modulation) architecture. A true showcase...
