TOPPING D90SE Balanced DAC ES9038Pro 32bit 768kHz DSD512 MQA Black
10%
The Topping D90SE is a high-end DAC, benefiting from an intelligent and careful design for high performance. It features an ESS ES9038Pro conversion chip, an XMOS interface and an Altera Max II CPLD. The D90SE is also versatile, with a complete connectivity and an integrated Bluetooth receiver.
4.8 / 5
Reduced price!
Reference : 15419
Limited special offer
899,00 €tax incl.
-10%
809,10 €tax incl.
674,25 € tax excl.
This product has been replaced by the Topping D90 III SABRE model.
Topping D90SE
Balanced DAC ES9038Pro 32bit 768kHz DSD512 Black
Topping D90SE DAC Symétrique ES9038Pro 32bit 768kHz DSD512 Noir
ES9038Pro DAC
The D90SE features an ESS Sabre ES9038Pro DAC chip, using the 32-bit HyperStream architecture to achieve an extremely high level of performance for incredibly accurate and transparent sound reproduction.
The D90SE performs independent I/V (current/voltage) conversion for the 8 channels of the ES9038Pro and then connects them in parallel. This technique allows for an ever increasing level of performance.
MQA Support
The D90SE supports the MQA (Master Quality Authenticated) format on its USB input, but also on its Coaxial, Optical and AES inputs. This format allows you to enjoy a quality as close as possible to the original recording of your music.
Bluetooth 5.0
Equipped with a Qualcomm CSR8675 chip, the D90SE offers Bluetooth 5.0 reception, convenient for remote music streaming directly from your smartphone. In addition, this chip supports the codecs aptX, aptX HD, aptX LL and LDAC, allowing to achieve a high quality sound in wireless.
XMOS XU216
The USB input of the D90SE uses a 2nd generation XMOS XU2013 16-core chip. This chip supports high sampling rates, up to 32bit 768kHz PCM and DSD512, as well as MQA. This chip is associated with a custom Thesycon driver.
Full connectivity
The D90SE benefits from a complete range of connectivity to adapt to all systems. We can find AES, USB-B, Optical, Coaxial, I2S LVDS via HDMI as well as Bluetooth 5.0 connectivity. For its outputs, the D90SE offers single-ended RCA and balanced XLR.
Topping D90SE DAC Symétrique ES9038Pro 32bit 768kHz DSD512 Noir Topping D90SE DAC Symétrique ES9038Pro
Switchable output
The D90SE offers a selectable output system. The audio stream can be routed to the XLR output, the RCA output or both. Moreover, it also allows to choose an output level. Thus, the XLR output can work in 4V or 5V and the RCA output in 2V or 2.5V.
Preamplifier function
In addition to the DAC mode with a fixed output level, the D90SE offers a DAC + preamplifier mode. In this mode, you can control the volume level. Thus, the D90SE can be directly associated with a power amplifier or active speakers.
CPLD Alter Max II
The Topping D90SE uses an Altera Max II CPLD to process the clock signal and thus optimize the quality of digital signals, significantly reducing jitter.
Topping D90SE review by Audio Science Review (Amir)
 It is not every day that every barrier we have seen in DACs gets shattered to new levels. We are seeing extreme attention to every aspect of this design to squeeze this much performance out of this ESS DAC. Just when we though the race was over, here comes one more over achiever! "
Test du Topping D90SE par Audio Science Review (Amir)
Product typeBalanced DAC
Inputs1x USB-B
1x AES
1x Coaxial
1x Optical Toslink
1x I2S LVDS via HDMI
Bluetooth 5.0
Outputs1x Stereo RCA
1x Stereo XLR
DAC ChipESS ES9038Pro
USB interfaceXMOS XU216
Supported Bluetooth codecsSBC, AAC, aptX, aptX LL, aptX HD, LDAC
Supported sampling ratesPCM up to 32bit 768kHz
DSD up to DSD512
RCA Line out measurements @ USB, 96kHz
THD+N @ A-Weighting< 0.00007% @ 1kHz
THD @ No-Weighting, 90kBw< 0.0008% @ 20Hz-20kHz
SNR @ A-Weighting127dB @ 1kHz
Dynamic range @ A-Weighting127dB @ 1kHz
Frequency response20Hz-20kHz (±0.1dB)
20Hz-40kHz (±0.3dB)
Output level2.1Vrms @ 0dBFS (Mode 4V)
2.6Vrms @ 0dBFS (Mode 5V)
Noise @ A-Weighting< 1.3µVrms
Crosstalk-124dB @ 1kHz
Channel balance0.3dB
Output impedance100Ω
XLR Line out measurements  @ USB, 96kHz
THD+N @ A-Weighting< 0.00005% @ 1kHz
THD @ No-Weighting, 90kBw< 0.0003% @ 20Hz-20kHz
SNR @ A-Weighting134dB @ 1kHz
Dynamic range @ A-Weighting134dB @ 1kHz
20Hz-40kHz (±0.3dB)
Output level4.2Vrms @ 0dBFS (Mode 4V)
5.2Vrms @ 0dBFS (Mode 5V)
Noise @ A-Weighting< 1.1µVrms
Crosstalk-139dB @ 1kHz
Dimensions222 x 160 x 45mm
Package1x Topping D90SE Black
1x IR Remote control
1x USB cable
1x Bluetooth antenna
1x Power cable
Topping D90SE DAC Symétrique ES9038Pro 32bit 768kHz DSD512 Noir Topping D90SE DAC Symétrique ES9038Pro 32bit 768kHz DSD512 Noir Topping D90SE DAC Symétrique ES9038Pro 32bit 768kHz DSD512 Noir Topping D90SE DAC Symétrique ES9038Pro 32bit 768kHz DSD512 Noir
InputI2S via HDMI
InputAES/EBU
DAC / ADC ChipES9038PRO
Max sampling rate768kHz
Max sampling rateDSD512
Remote ControlYes
4 reviews
TOPPING D90SE DAC Symétrique ES9038Pro 32bit 768kHz
Belle écoute très détaillée, , sans atteindre celle d'un NANOLAB sonata , mais très agréable, avec en plus des basses bien tendues, et étendues. Il manque juste de la "matière" dans les voix, notamment , par rapport a des DAC bien plus couteux...!
Bon rapport qualité prix.
This review has been posted for TOPPING D90SE Balanced DAC ES9038Pro 32bit 768kHz DSD512 MQA Black
Transparence
C'est un upgrade par rapport à la précédente gamme de mini Dac. Topping arrive le tour de force à faire compact, d'une finition parfaite. D'une connectique absolument complète. Et surtout d'une qualité sonore formidable. C'est transparent; ultra détaillé avec une bande passante droite d'un point à l'autre de l'horizon. J'aime le son des puces ESS.
Je l'écoute sur des casques planars magnétiquesexigeants et sans pitié de très très haut de gamme et c'est un sans faute.
Comme toute la gamme Topping il doit impérativement être alimenté par une source de qualité en AES/EBU, sortie en XLR et avec une alimentation secteur très propre (câbles,EMI, etc...). C'est le prix à payer de la transparence et elle est exigeante.
Seul défaut le prix monte, mais très vite oublié à la première écoute quand il est associé au derniers ampli casque de la même marque en version Discrète qui est un bijou aussi et ils sont fait pour s'aimer.
Bien sûr il y a d'autres marques qui postulent dans la même gamme mais si vous voulez LE CHAMPION qui a un plus un peu spécial c'est cette gamme Topping.
Méfiez vous simplement car ils progressent très très vite et on se demande jusqu'où ils ralentiront dans l'excellence du MIDFI.
Bien à vous.
Réellement bluffant !
Tout d'abord un grand merci à Audiophonics avec qui cela se passe toujours bien et pour importer du matériel hélas peu courant dans nos contrées.
Pour ce qui est de ce topping D90SE et bien que dire de plus que ce que l'on peut lire sur le net ?
D'accord il est petit et peut paraitre fragile, ce n'est pas un très beau châssis monobloc en alu anodisé à protection galvanique avec un bel écran Oled couleur. Et alors ?
Vous regardez souvent votre matériel lorsque vous écoutez de la musique ?
Car il s'agit bien là du point majeur de cette petite boite : Il transcende la musique dans le meilleur sens qui soit à savoir, dynamisme, clarté des timbres, très méticuleux dans le respect de la répartition spatiale des instruments et des voix.
J'ai eu de (très voire trop, bien trop) chers DAC qui ne faisaient pas le même boulot ... Regarder vers une certaine marque canadienne par exemple... dont le lecteur réseau / DAC / preamp dépasse les 7 000 € !
Alors oui il faut lui adjoindre un très bon lecteur réseau pour profiter de cette petite bombe... Moi c'est un SOtM ultra avec son alim dédiée et c'est un pur régal.
Cette petite boite n'a pas à rougir vraiment !!!! A ce prix c'est à peine croyable... Félicitations
 (5)
Il a tout d'un grand !
Je cherchais un convertisseur "haut de gamme" pas trop encombrant et pas trop cher.
Je l'utilise principalement avec l'entrée USB et les sorties XLR reliées directement à un ampli de puissance PURIFI.
J'ai pu le comparer avec un Audio-gd nfb-11-38 équipé de la même puce. Un gain musical indéniable et un remarquable silence de fonctionnement.
Beaucoup de fonctions pratiques. Je me sers des sorties RCA reliées à un petit ampli Topping L30 pour une écoute occasionnelle au casque.
Simplement, les câbles secteur et USB d'origine sont à remplacer d'office !
 (3)
The Topping D90SE is a high-end DAC, benefiting from an intelligent and careful design for high performance. It features an ESS ES9038Pro...
