TOPPING DX3 PRO+ DAC ES9038Q2M NFCA Headphone Amplifier TPA6120A2 Bluetooth 5.0 aptX HD LDAC XMOS 32bit 768kHz DSD512 Black
Topping unveils its DX3Pro+, a direct evolution of the excellent DX3Pro, an excellent compact DAC also offering headphone amplification and preamplification functions. Embarking in particular an ES9038Q2M conversion chip and a XMOS XU208 USB interface, it ensures a particularly precise and lively sound reproduction. It also benefits from a Bluetooth receiver, practical for broadcasting music remotely, from a smartphone for example.
Reference : 15685
199,00 €tax incl.
165,83 € tax excl.
This product is temporarily unavailable.
Topping DX3Pro+
DAC ES9038Q2M NFCA Headphone Amplifier Bluetooth 5.0 aptX HD LDAC XMOS XU208 32bit 768kHz DSD512 Black
Topping DX3pro+ DAC ES9038Q2M Amplificateur Casque NFCA Bluetooth 5.0 aptX HD LDAC XMOS XU208 32bit 768kHz DSD512
ESS ES9038Q2M DAC
The digital/analog conversion stage of the DX3Pro+ is based on a DAC ES9038Q2M chip from ESS. This one offers excellent performances and benefits from an advanced optimization, made by the brand for an increased efficiency. The DAC is thus able to advance a THD+N of 0.00015%.
USB XMOS XU208 USB Interface
In addition to this ES9038Q2M DAC chip, there is a second generation XMOS XU208 8-core USB interface, in charge of processing the data transmitted via the USB input. This one allows notably the support of high resolution audio streams, with PCM up to 32bit 768kHz and DSD up to DSD512. This chip also offers excellent compatibility with the majority of systems, whether the device is running Windows 10, Mac OS, Linux, iOS or Android.
QCC5125 & Bluetooth 5.0
The DX3Pro+'s Bluetooth 5.0 reception is provided by a QCC5125 chip designed by Qualcomm. This allows the DX3Pro+ to benefit from Hi-Res Wireless certification, thanks to the support of high-quality transmission codecs such as aptX, aptX LL, aptX HD and LDAC.
To achieve even better performance, this Bluetooth input is directly linked to the ES9038Q2M DAC for decoding the audio stream.
NFCA Circuit
The DX3Pro+ benefits from Topping's new NFCA circuitry, specially optimized for this model. This allows for ultra-low noise and distortion. This technology also allows the DX3Pro+ to be used with both high-sensitivity headphones and high-impedance headphones.
Adjustable gain
To ensure compatibility with the widest range of headphones on the market, the DX3Pro+ features a two-level gain control: a low gain level at +6dB and a high gain level at +19dB.
Preamplifier Function & Output Modes
The DX3Pro+ offers a preamplifier function and no less than four output modes to suit different uses:
  • Headphone amplifier output
  • Headphone amplifier output + line output
  • DAC
  • Preamplifier
Output channelIndicatorJack 3.5mm headphone outpoutRCA outputAdjustable volume
Headphone amplifierHeadphone indicator ON
Headphone amplifier + Line outputHeadphone indicator ON
DAC indicator ON
Line outputDACIndicateur DAC allumé
Taux d'échantillonnage affiché
PreamplifierDAC indicator ON
Volume displayed
DX3Pro+ vs DX3Pro
DX3Pro+
DX3Pro
Bluetooth
QCC5125
CSR8675
THD+N (DAC)
0.00015%
0.0004%
THD+N (Headphone amplifier)
0.00015% @ 1500mW, 32 Ohm
0.001% @ 77mW, 32 Ohm
Output power
2x1800mW @ 32 Ohm
2x 250mW @ 300 Ohm
2x700mW @ 32 Ohm
2x 125mW @ 300 Ohm
Output impedance
< 0.1 Ohm
< 10 Ohm
Product typeDAC
Headphone amplifier
Preamplifier
Inputs1x USB-B
1x Optical Toslink
2x Coaxial
Bluetooth 5.0
Outputs1x Stereo RCA
1x Jack 3.5mm headphone output
Amplification chipTPA 6120A2
DAC chipESS ES9038Q2M
Bluetooth chipQCC5125
Supported sampling ratesUSB : PCM up to 32bit 768kHz, Native DSD up to DSD512, DSD DoP up to DSD256
Coaxial / Optical : PCM up to 24bit 192kHz, DSD DoP up to DSD64
Supported Bluetooth codecsAAC, SBC, aptX, aptX LL, aptX HD, LDAC
DAC Measurements (@ USB, 96kHz)
THD+N @ 1kHz, A-Weighting< 0.00015%
THD @ 20Hz-20kHz, 90kBW< 0.0002%
SNR @ 1kHz, A-Weighting122dB
Dynamic range @ 1kHz, A-Weighting122dB
Frequency response20Hz-20kHz (±0.3dB)
20Hz-40kHz (±0.7dB)
Output level2.1Vrms @ 0dBFS
Noise @ A-Weighting< 1.8µVrms
Crosstalk @ 1kHz-137dB
Channel balance0.3dB
Output impedance20Ω
Headphone amplifier measurements
THD+N @ 1kHz, A-Weighting< 0.00015% @ Output=1500mW, 32Ω
< 0.00013% @ Output=160mW, 300Ω
THD @ 20Hz-20kHz, 90kBW< 0.0005% @ Output=1500mW, 32Ω
< 0.0005% @ Output=160mW, 300Ω
SNR @ Max output level, A-Weighting120dB
Dynamic range @ 1kHz, A-Weighting120dB
20Hz-40kHz (±0.7dB)
Output level5.5Vpp @ G=L
21.5Vpp @ G=H
Noise @ A-Weighting< 2.1µVrms @ G=L
< 7µVrms @ G=H
Crosstalk @ 1kHz-90dB
Gain6dB (Vrms/FS) @ G=L
19dB (Vrms/FS) @ G=H
Output impedance< 0.1Ω
Output power2x 1800mW @ 32Ω, THD+N < 0.1%
2x 900mW @ 64Ω, THD+N < 0.1%
2x 250mW @ 300Ω, THD+N < 0.1%
Adapter impedance> 8Ω
Dimensions120 x 165 x 40mm
Housing materialAluminum
Package1x Topping DX3Pro+
1x Power supply
1x Remote control
1x USB Cable
1x Bluetooth antenna
Topping DX3pro+ DAC ES9038Q2M Amplificateur Casque NFCA Bluetooth 5.0 aptX HD LDAC XMOS XU208 32bit 768kHz DSD512 Topping DX3pro+ DAC ES9038Q2M Amplificateur Casque NFCA Bluetooth 5.0 aptX HD LDAC XMOS XU208 32bit 768kHz DSD512 Topping DX3pro+ DAC ES9038Q2M Amplificateur Casque NFCA Bluetooth 5.0 aptX HD LDAC XMOS XU208 32bit 768kHz DSD512
OutputJack 3.5mm
DAC / ADC ChipES9038Q2M
Max sampling rateDSD512
Max sampling rate768kHz
Amplifier chipN/A
Remote ControlYes
10 reviews
Excellent rapport qualité prix
Fabrication propre , pratique à utiliser, aucun problème à l'installation. Il drive très bien mon hifiman sundara.
Au niveau sonore, c'est exactement ce que je recherche et rien à lui reprocher.
Le seul défaut que je vois est le bruit que fait l'alimentation au niveau de la prise. C'est léger mais suffisant quand je n'écoute pas le casque pour que je regarde à la remplacer.
This review has been posted for TOPPING DX3 PRO+ DAC ES9038Q2M NFCA Headphone Amplifier TPA6120A2 Bluetooth 5.0 aptX HD LDAC XMOS 32bit 768kHz DSD512 Black
DAC TOPPING DX3 PRO+
excellent DAC, correspond a mes attentes, HI RES enfin disponible sur mon installation HI-FI.
Son de très bonne qualité.
Great Price/Value
Bought it with a Hifiman Sundara, mostly use it with my daily AKG K7XX.
It is perfect for both, I use software EQ to aligh them, and ASIO for low latency. (Gaming/Shaker setup)
Sound is very good.
One flaw is some of the segments of the display went bad, but its not affecting anything, and they are mostly off anyway.
affichage defectueux
Depuis quelques mois, l'affichage en Db a perdu 2 segments sur le zero et le trois.
Imbattable dans son genre et à ce prix
Imbattable si vous comprenez
Sur ce créneau tarifaire et si on fait le compte de la techno embarquée, de la qualité de conception et des possibilités DAC/ Ampli casque, cet appareil largue toute concurrence.
Il faut cependant prendre en compte l'orientation analytique un peu sèche. Avec un Beyer DT 900 Pro la matière et la définition sont somptueuses mais épuisantes.
Fonctionne de manière superbe avec un HE-500 et un LCD-2 Closed Back. Il y a peut-être une piste pour une certaine apétence pour les orthos ?
Sur un Koss ESP 950 en mode DAC, ça manque un peu d'ampleur et de maitrise mais sans doute aussi bon voire certainement meilleur qu'avec n'importe quel autre DAC à prix équivalent.
Topping unveils its DX3Pro+, a direct evolution of the excellent DX3Pro, an excellent compact DAC also offering headphone amplification and...
