This 32bit 384Khz DAC offers the latest generation of ESS SABRE ES9028 PRo chips with true balanced outputs and a powerful adjustable digital volume level. Of a high quality design with a powerful Amanero USB input, it offers a first-rate sound performance at a tight budget.
By buying this product you get 37 loyalty points
This DAC based on ES9028 Pro 32bit chips offers formidable performance at a reasonable budget. Equipped with a truly symmetrical DAC output scheme with two XLRs, it is possible to control, for example, a pair of active studio speakers or a power amplifier thanks to the ESS SABRE volume, the best digital volume on the market.
Its Amanero dual clock USB input with galvanic isolation is most powerful using a programmable FPGA and not a chip already integrated. Using a TCXO 100Mhz clock of 0.1PPM with its own dedicated regulation this DAC offers a great precision coupled with an exceptional musicality in a contained budget.
The analog outputs are really balanced since the conversion and respect the ESS specifications with a "Quad differential" scheme allowing a great dynamics, a great background noise reduction. All 6 LM49990 PDOs on the circuit are on interchangeable DIP 8 holders, allowing the PDOs to be changed for more efficient models at will. In addition, the power supply has 10 LDO regulations and low noise subgroups guaranteeing a high purity signal even on small details and harmonics.
This audio converter features only quality components with Wima, Elna, Panasonic capacitors, shielded transformer, fast diodes and metal to film resistors.
Output | RCA |
Output | XLR |
DAC / ADC Chip | ES9028PRO |
Max sampling rate | 384kHz |
Max sampling rate | DSD512 |
Color | Silver |
Drivers AMANERO Vista WIN 7 / WIN 7 / WIN 8 32bit 64bit 64bit
Download (1.48M)
