FOSI AUDIO Q6 DAC
The Fosi Audio Q6 is a small, minimalist, high-performance desktop DAC based on an AKM AK4493SEQ solution and an XMOS XU316 USB interface. It supports high-fidelity sampling rates up to PCM 32bit 768kHz and DSD512, with clean, uncolored conversion for the most balanced sound reproduction.
Reference : 20773
99,00 €tax incl.
82,50 € tax excl.
Shipping date: 16-12-2025.
Fosi Audio Q6 DAC AK4493SEQ XMOS XU316 PCM 32bit 768kHz DSD512
Photo of FOSI AUDIO Q6
The Fosi Audio Q6 is a small, minimalist, high-performance desktop DAC based on an AKM AK4493SEQ solution and an XMOS XU316 USB interface. It supports high-fidelity sampling rates up to PCM 32bit 768kHz and DSD512, with clean, uncolored conversion for the most balanced sound reproduction. In terms of performance, it offers ultra-low distortion with a THD+N of 0.00012%, a noise figure of just 2.8uV and an SNR of up to 121dB. It also features a combination of DIP8-mounted AOP OPA1612 + NE5532DR. Control of the device is simple and efficient. Connectivity includes three digital inputs: USB-C, Toslink optical and coaxial, as well as an RCA output and a subwoofer output for setting up a 2.1-channel system with an active subwoofer.
FOSI AUDIO Q6 highlights
Fosi Audio Q6 DAC overview
1Switch ON-OFF
2Sampling rate indicator
3Input switch
4USB-C input / USB 5V 2A power port
5Toslink optical input
6Coaxial input
7RCA output
8Subwoofer output
Fosi Audio Q6 test by Audio Science Review
The Q6 doesn't break any barrier but is competently designed for its price point with some innovation on input selection and such.
Performance is good enough for me to put the Fosi Q6 on my recommendation list for a budget DAC.
Logo ASR
Product typeDAC
DAC chipAK4493SEQ
USB interfaceXMOS XU-316
OPAOPA1612 + NE5532DR
Inputs1x USB-C
1x Optical Toslink
1x Coaxial
Outputs1x RCA output
1x Subwoofer output
Supported sample ratesUSB: PCM up 32bit 768kHz, DSD up to DSD512
Toslink optical / Coaxial: PCM up to 32bit 192kHz
THD< 0,00012%
SNR≥ 121dB
USB-compatible OSXP/W7/W8/W10/W11/MAC/Linux
Power supply5V 2A via USB-C
Dimensions105 x 142 x 37mm
Weight410g
Package1x DAC Q6
1x USB-C to USB-C/A cable
OutputSubwoofer
DAC / ADC ChipAK4493SEQ
Max sampling rateDSD512
Max sampling rate768kHz
ColorGray
FOSI AUDIO Q6 DAC AK4493SEQ XMOS XU316 32bit 768kHz DSD512
The Fosi Audio Q6 is a small, minimalist, high-performance desktop DAC based on an AKM AK4493SEQ solution and an XMOS XU316 USB interface. It...
