Great DAC and quick order handling and shipping.
By buying this product you get 138 loyalty points
Holo Audio presents the big brother of its CYAN DAC, the CYAN 2. Like its predecessor, this is a balanced R2R DAC, based on discrete resistor networks. In addition, it operates in NOS (Non-Over-Sampling) mode for very pure, authentic signal restitution. Here are the main improvements on version 2 of the CYAN DAC:
Holo Audio's CYAN 2 DAC is one of the first to support native DSD via its R2R ladder architecture. The CYAN 2 module has been specially optimized for this application, and runs on MAC (DOP), Linux (DOP), and Windows/PC (Direct Native and DOP).
The CYAN 2's Altera MAX II CPLD is used to process the clock signal and optimize the quality of the digital sound signal by considerably reducing the jitter rate.
Equipped with an I2S port via HDMI connector, the CYAN 2 lets you enjoy the very best in audio transmission. Please note that the pinout is proprietary to Holo Audio, although it is similar to the PS Audio standard. Left and right channels are inverted for DSD streams.
Please note that I2S is not the same as HDMI Audio/Video signals. Never connect an HDMI device to the CYAN 2's I2S port. Make sure your source device is I2S-compatible and has a similar pinout configuration.
1 | RCA analog output |
2 | Balanced XLR analog output |
3 | SPDIF Coaxial input |
4 | I2S input via HDMI |
5 | Toslink optical input |
6 | USB-B input |
7 | AES/EBU input |
8 | Power socket / Fuse slot / Power switch |
This product works with both 220V AC and 110V AC supply voltage. By default, however, it is set for use with 220V AC. For use on 110V AC, it is necessary to set the device to this supply voltage via an internal switch before use and connection.
Product type | Balanced DAC R2R |
Inputs | 1x USB-B 1x AES/EBU 1x Optical Toslink 1x SPDIF Coaxial 1x I2S via HDMI |
Outputs | 1x RCA 1x Balanced XLR |
Supported sample rates | USB (Galvanic isolation) : PCM 32Bit 1536MHz, DSD DOP64-512, DSD Native up to DSD1024 I2S: PCM 32Bit 1536MHz, DSD Native up to DSD1024 AES/EBU, Optical Toslink, SPDIF Coaxial: PCM 24bit 192kHz, DSD DOP64 |
Input selection | Automatic |
MEASUREMENT OF ANALOG OUTPUTS | |
PCM 48K NOS | THD +N : 0.0005% @ 1kHz (-106dB) DNR : -127dB Output voltages : 2.5Vrms (RCA), 5Vrms (XLR) |
DSD128X | THD +N : 0.0002% @ 1kHz (-114dB) DNR : -115dB Output voltages : 1.25Vrms (RCA), 2.5Vrms (XLR) |
general | |
Adjustable power supply | 220-230V 50/60Hz (fusible : 2A SB 5x20mm) 110-115 V 50/60 Hz (fusible : 4A SB 5x20 mm) (power cable not included) |
Energy consumption | 20W |
Dimensions | 300 x 200 x 48mm |
Weight | 3.5kg |
Package | 1x DAC R2R Holo Audio CYAN 2 1x USB-A to USB-B cable |
Input | Optical |
Input | AES/EBU |
Input | SPDIF |
Input | I2S via HDMI |
Input | USB |
Output | XLR |
Output | RCA |
Max sampling rate | DSD1024 |
Max sampling rate | 1536kHz |
Color | Black |
Networking | No |
Remote Control | No |
Average votes 4.9 / 5 9 reviews | Why write products reviews ? You can share your feelings about products and help other people by sharing your experience |
Johan L.
Fabien A.
Xavier P.
Benjamin M.
Jean François N.
