By buying this product you get 134 loyalty points
The Musician Pegasus presents itself as a magnificent and particularly powerful DAC, taking advantage of a neat R2R architecture. Integrating the best current technologies, the device benefits from a low-noise power supply, a FIFO buffer, signal processing by FPGA and a FIR filter. It is thus capable of decoding very high sample rates, up to 32bit PCM 1536kHz and DSD1024 via its USB and I2S inputs. The USB interface is managed by a STM32F446 MCU with Thesycon driver. The whole unit is integrated in a massive Aluminium case.
Version II of the Musician Pegasus DAC features an upgrade of its internal components for enhanced performance. This time it benefits from an Altera Cyclone IV chip, as well as audiophile-grade capacitors and independent power supplies for its digital and analog parts.
The Musician Pegasus II provides you with most of the connections common to today's HiFi devices. We thus find at the input of USB-B, I2S via HDMI LVDS, AES/EBU, Toslink Optics and Coaxial. On the output side, the device offers unbalanced RCA and balanced XLR, the latter output being obviously recommended to take advantage of the full potential of the device.
It is not recommended to use the XLR and RCA outputs simultaneously, as these are shared.
1 | Input selector |
2 | Power button |
3 | NOS button |
4 | RCA right channel output |
5 | XLR right channel output |
6 | XLR left channel output |
7 | RCA left channel output |
8 | I2S input via HDMI |
9 | Coaxial input |
10 | Optical Toslink input |
11 | AES input |
12 | USB-B input |
13 | Power supply input |
To make it compatible with most devices, the Musician Pegasus offers several configurations of its I2S pinout. To modify this setting, follow the steps below:
If the setting does not produce satisfactory sound (e.g. a hissing noise), this cannot be considered a device malfunction, but simply an incompatibility. The recommended solution is to use a customized HDMI cable, adapted to the pinout of your device and the Pegasus.
Product type | DAC R2R |
Inputs | 1x USB-B 1x Coaxial 1x Optical Toslink 1x AES/EBU 1x I2S via HDMI LVDS |
Outputs | 1x Single-ended RCA 1x Balanced XLR |
Supported sampling rates | I2S / USB : PCM up to 32bit 1536kHz, DSD up to DSD1024 Others inputs : PCM up to 24bit 192kHz, DSD DoP up to DSD64 |
Frequency response | 10Hz - 60kHz |
THD+N | 0.002% |
SNR | 123dB (A-Weighted) |
Dynamic range | > 120dB |
Output level | RCA : 2.2Vrms XLR : 3.55Vrms |
Supply voltage | 110-240VAC, 50/60Hz |
Consumption | ≤ 20W |
Dimensions | 280 x 250 x 50mm |
Weight | 3.9kg |
Color | Silver |
Package | 1x Musician Pegasus II 1x Power cable |
Pinout I2S | ||||||||
PIN | Mode 1 | Mode 2 | Mode 3 | Mode 4 | Mode 5 | Mode 6 | Mode 7 | Mode 8 |
1 | DATA- | DATA- | DATA+ | DATA+ | DATA- | DATA- | DATA+ | DATA+ |
3 | DATA+ | DATA+ | DATA- | DATA- | DATA+ | DATA+ | DATA- | DATA- |
4 | BCK- | BCK- | BCK- | BCK- | BCK+ | BCK+ | BCK+ | BCK+ |
6 | BCK+ | BCK+ | BCK+ | BCK+ | BCK- | BCK- | BCK- | BCK- |
7 | LRCK- | LRCK+ | LRCK- | LRCK+ | LRCK- | LRCK+ | LRCK- | LRCK+ |
9 | LRCK+ | LRCK- | LRCK+ | LRCK- | LRCK+ | LRCK- | LRCK+ | LRCK- |
Input | USB |
Input | Optical |
Input | AES/EBU |
Input | SPDIF |
Input | I2S via HDMI |
Output | XLR |
Output | RCA |
DAC / ADC Chip | NC |
Max sampling rate | DSD1024 |
Max sampling rate | 1536kHz |
Color | Silver |
Networking | No |
Remote Control | No |
