SMSL D1 DAC
New
The SMSL D1 is a budget DAC based on high-quality components. Digital-to-analog conversion is performed by a USB XMOS XU-316 interface combined with a Rhom BD34352EKV chip, enabling it to achieve an SNR of 126dB while supporting high-resolution streams up to PCM 32bit 768kHz and DSD512.
Reference : 20843
79,00 €tax incl.
65,83 € tax excl.
SMSL D1 DAC ROHM BD34352EKV XMOS XU316 32bit 768kHz DSD512
Photo du SMSL D1
The SMSL D1 is a budget DAC based on high-quality components. Digital-to-analog conversion is performed by a USB XMOS XU-316 interface combined with a Rhom BD34352EKV chip, enabling it to achieve an SNR of 126dB while supporting high-resolution streams up to PCM 32bit 768kHz and DSD512. The USB-C input is complemented by a Toslink optical input and a coaxial SPDIF input, and the output is on an RCA connector. The SMSL D1 can be adapted to a variety of scenarios, whether you need to connect a source such as a computer, a smartphone via USB, or a DVD player, a TV via optical/SPDIF.
Les connexions du SMSL D1
SMSL D1 overview
Aperçu du SMSL D1
1Touch input selector
2Touch power button
3RCA output
4Coaxial input
5Toslink optical input
6USB-C DAC input
7USB-C power port
Product typeDAC
DAC chipROHM BD34352EKV
USB interfaceXMOS XU316
Inputs1x USB-C
1x Toslink optical
1x Coaxial
Outputs1x RCA output
Output level2Vrms
THD+N0.00038% (-108dB)
Dynamic range119dB
SNR119dB
Supported sample ratesUSB: PCM up to 32bit 768kHz, DSD up to DSD512
Toslink optical and coaxial: PCM up to 24bit 192kHz
USB transmissionAsynchronous
USB compatibilityWindows 7/8/8.1/10/11
Mac OS
Linux
Alimentation5V 1A via USB-C
Power consumption< 5W
Standby: < 0.1W
Dimensions101 x 33 x 90.1mm
Weight201.1g
Package1x DAC SMSL D1
DAC / ADC ChipROHM BD34301EKV
Max sampling rateDSD512
Max sampling rate768kHz
The SMSL D1 is a budget DAC based on high-quality components. Digital-to-analog conversion is performed by a USB XMOS XU-316 interface combined...
