By buying this product you get 27 loyalty points
The MKII version of this product offers the Bluetooth 5.0 function, as well as a 3.5mm jack port for SPDIF Coaxial and Optical Toslink connection.
To use it, you can use a Mini-Toslink optical cable, or a 3.5mm Jack to RCA Male mono adapter for coaxial cable.
DAC AKM AK4497 XMOS Dual NDK Clock 32bit 768kHz DSD512 Blue
The SMSL M300 MKII is a high-performance and compact DAC in an atypical format. Integrating high quality components as well as a Bluetooth 5.0 connection, it is the perfect ally to offer to your HiFi audio system a digital/analog converter capable of restoring your audio files with a beautiful transparency but also an astonishing sound richness.
The M300 is equipped with an AK4497EQ high-end DAC chip from AKM. The latter supports high sampling rates, in PCM up to 32bit 768kHz and in DSD up to DSD512. In addition, the chip uses the proprietary Velvet Sound architecture allowing it to provide a high SNR (128dB) and very low distortion (THD+N -116dB) for neutral and accurate reproduction, with a beautiful sound image.
This chip is combined with many quality components such as a second-generation XMOS USB interface, two ultra-low phase noise Japanese NDK clocks to significantly limit jitter on 44.1kHz / 48kHz and multiple frequencies, and finally a series of resistors and capacitors specially designed for audio use.
All components are integrated into a beautiful CNC machined Aluminium housing, both robust and allowing to limit interference that could degrade the audio signal. The front panel is covered with a tempered glass plate of the most beautiful effect and a 1.54" IPS screen, allowing you to display all the information related to the reading of your files (input, filter, sampling rate, read format...). The control is done simply with the two buttons on the front panel, allowing you to turn the device on/off, select an input, change the display color or choose an audio filter.
The back of the device contains all the connectors. We find at the input of the SPDIF Optical / Coaxial via Jack 3.5mm, the Micro USB (XMOS), as well as the Bluetooth antenna. On the output side, the M300 offers balanced XLR or unbalanced RCA.
" We really liked the fullness of the sound reproduction of the DAC S.M.S.L M300. The contribution of its various digital filters is interesting while preserving the excellent musical quality of this device. "
This is a test of the previous version of the SMSL M300 (not the MKII version). The test is therefore available here for reference, but the MKII version is an improved version of the one presented in the test.
Product type | DAC |
Inputs | 1x Micro USB XMOS 1x Bluetooth 5.0 AptX 1x S/PDIF Coaxial / Toslink via Jack 3,5mm |
Outputs | 1x Single ended RCA 1x Balanced XLR |
Output level | RCA : 2Vrms XLR : 4Vrms |
THD+N | 0.0004% |
Dynamic range | RCA : 120dB XLR : 123dB |
SNR | 116dB |
USB compatibility | Windows 7 / 8 / 8.1 / 10 Mac OSX 10.6 or more Linux |
Sampling rate/ Bit depth | USB : Up to 32bit 768kHz / DSD512 Optique / Coaxial : Up to 24bit 192kHz |
Consumption | 1.8W |
Standby consumption | < 0.1W |
Dimensions (WxHxD) | 70 x 70 x 160mm |
Weight | 500g |
Power supply delivered | Yes |
Package | 1x SMSL M300 MKII Blue 1x Power supply 1x Remote Control 1x Antenna 1x Optical cable 1x Jack 3.5mm to RCA cable 1x Micro USB to USB-A cable |
Input | Optical |
Input | SPDIF |
Output | XLR |
Output | RCA |
DAC / ADC Chip | AK4497EQ |
Max sampling rate | 768kHz |
Max sampling rate | DSD512 |
Color | Blue |
Networking | No |
Remote Control | Yes |
