SMSL PS200 PRO DAC
The SMSL PS200 PRO is a compact and versatile DAC, designed to deliver exceptional sound quality at an affordable price. Equipped with the latest-generation ES9039Q2M DAC chip and the XMOS XU316 USB processor, this DAC supports high-resolution audio formats up to 32-bit/768kHz PCM and DSD512, as well as MQA and MQA-CD decoding. Its ultra-lightweight design and CNC-machined aluminum chassis make it an ideal choice for desktop setups, gaming, or even on the go.
Reference : 21691
89,90 €tax incl.
74,92 € tax excl.
Shipping date: 01-12-2026.
SMSL PS200 PRO DAC ES9039Q2M XMOS XU316 32bit 768kHz DSD512 MQA
SMSL PS200 PRO
SMSL PS200 PRO: Clear and precise sound
The PS200 PRO stands out for its ability to reproduce neutral, faithful sound, free from coloration or distortion. Thanks to its four OPA1612A operational amplifiers, dedicated clock processing circuit, and low-noise power supply, it guarantees low distortion (THD+N at 0.00009%) and a high signal-to-noise ratio (125dB), for clear and detailed listening.
SMSL PS200 PRO: Comprehensive connectivity
This DAC offers a wide range of connectivity options: USB (UAC1/UAC2), optical, and coaxial. UAC1 mode enables plug-and-play connectivity with gaming consoles such as the PS5 or Nintendo Switch, while UAC2 mode is optimized for computers and Hi-Fi systems. Its USB-C power supply and low power consumption make it both convenient and cost-effective.
SMSL PS200 PRO: Compact and sturdy design
With its compact dimensions (100 x 23 x 84.7mm) and lightweight design (168.5g), the PS200 PRO fits easily into any environment. Its CNC-machined aluminum housing ensures excellent heat dissipation and protection against interference, while offering a premium finish.
SMSL PS200 PRO : Diagram
1ON-OFF button / Input switch
2USB-C / power supply input
3UAC1 / UAC2 switch
4Optical Toslink input
5Coaxial input
6RCA input
Test of the SMSL PS200 by Audio Science Review
"In both case, these are two high performing DACs for little money. I am really amazed by the level of linearity achieved by these low-cost DACs.
As promised, SMSL managed to increase the performances, with the PRO version, to reach top level from unbalanced output of a DAC. Provided you don't need Bluetooth input, then you get high-end performances in a refined metallic case."
Product typeDAC
DAC chipES9039Q2M
USB interfaceXMOS XU316
Inputs1x USB-C
1x Optical Toslink
1x Coaxial
Output1x Stereo RCA
Supported sampling ratesUSB: PCM up to 32bit 768kHz, DSD up to DSD512, DoP256
Optical, coaxial : PCM up to 24bit 192kHz, DoP64
Output level2Vrms
THD+N0.00009% (-120.5dB)
Dynamic range125dB
SNR125dB
Compatibility USBWindows 7/8/8.1/10/11 (driver needed), Mac OS X 10.6+, Linux, Android, iOS, Sony PS5 (UAC1), Nintendo Switch (UAC1)
UAC1, UAC2 (switchable)
Dimensions100 x 84.7 x 23mm
Weight168.5g
Consumption< 5W
En veille : < 0.1W
Package1x SMSL PS200 PRO
1x USB cable
DAC / ADC ChipES9039Q2M
Max sampling rateDSD512
Max sampling rateMQA
Max sampling rate768kHz
3 reviews
Incroyable cette petite boite
Monté en attente de mon prochain Dac Gustard sur preampli Luxman et A48, et bien je ne m'attendais pas a ce niveau de son, propre et détaillé, son point faible peut être .... fatigue auditive en cas de longue écoute , mais je recommande en bureau et/ou hifi vintage ????
This review has been posted for SMSL PS200 PRO DAC ES9039Q2M XMOS XU316 32bit 768kHz DSD512 MQA
Dac écologique
Très bonne qualité audio, de plus tout riquiqui donc utilisant peu matière donc à faible empreinte carbone. Ils sont fort les chinois, va falloir se retrousser les manches pour faire mieux !
Pourquoi payer plus cher ?
Ce DAC totalement 'transparent' avec ses mesures exceptionnelles est tout simplement parfait !
Afin d'éviter les 'faux soucis' d'installation du driver XMOS sous WINDOWS 11, il faut que le sélecteur situé à l'arrière soit en position 'UAC 2' et que vous installiez le driver en mode administrateur et après tout fonctionne parfaitement (j'utilise le Player 'Music Bee'). Bonnes écoutes à tous ;)
The SMSL PS200 PRO is a compact and versatile DAC, designed to deliver exceptional sound quality at an affordable price. Equipped with the...
