The FiiO Snowsky Disc is a digital audio player (DAP) that combines a retro design inspired by CD walkmans with modern audio technology. Ultra-compact and lightweight, it slips easily into a pocket and features a distinctive 1.8inch (360x360px) disc-shaped IPS display. It features two CS43131 DAC chips, compatible with 32bit 384kHz PCM and DSD128, and an Ingenic X2000 processor, delivering faster processing speeds for an enhanced music listening experience.
In addition, the Snowsky Disc features Wi-Fi connectivity, Bluetooth 5.4, as well as a single-ended 3.5mm output and an balanced 4.4mm jack output delivering up to 280mW, all designed to cater to a wide range of on-the-go use cases.
The Snowsky Disc is equipped with two CS43131 DAC chips, enabling it to support audio formats up to 32bit 384kHz PCM and DSD128 within a balanced audio circuit with an independent power supply. With a signal-to-noise ratio of 129dB and low output impedance (32Ω), it ensures precise control of the transducers, even with demanding headphones or earphones. The player can deliver up to 125mW via its 3.5mm single-ended output and 280mW via its 4.4mm balanced output, providing sufficient power for a wide range of headphones and earphones
The Snowsky Disc features Wi-Fi connectivity with Airplay support and Bluetooth 5.4 with LDAC support, enabling a fast, stable and high-fidelity wireless connection to Bluetooth headphones or speakers for on-the-go listening. It also features a microSD card slot supporting cards up to 2TB (not included), and offers approximately 12 hours of continuous playback thanks to its 1450mAh battery.
The retro design of the Snowsky Disc makes this device as stylish as it is high-performing. The Snowsky Disc can play audio files (DSD, MP3, OGG, WMA, AAC, WAV, FLAC) from a microSD card or via USB (in DAC mode), and stream to headphones or earphones via Bluetooth. With a vintage style reminiscent of CD players, its robust aluminium casing and circular IPS screen offer a variety of dynamic user interfaces that support the display of album covers and lyrics. Furthermore, it also provides access to an equaliser with 8 modes, such as "retro" and "pop", as well as numerous filters allowing for complete listening customisation. Finally, its X2000 processor and Linux-based OS are designed to ensure an optimal listening experience by focusing on the music itself.
| Specifications | |
| Product type | Digital music player (DAP) |
| Inputs | Bluetooth 5.4 1x MicroSD card slot (up to 2TB, not included) 1x USB-C |
| Outputs | Bluetooth 5.4 1x 3.5mm single-ended headphone output / coaxial output combo 1x 4.4mm balanced headphone jack |
| WiFi | 2.4GHz Airplay Support |
| DAC chips | 2x CS43131 |
| Processor | Ingenic X2000 |
| Screen | 1.8inch LCD (360x360 pixels) |
| Battery capacity | 1450mAh |
| Battery life | 12h |
| Charging time | 1.5h |
| Supported Bluetooth codecs | AAC, SBC, LDAC |
| Supported file formats | DSD, MP3, OGG, WMA, AAC, WAV, FLAC |
| Supported sampling rates | DSD up to DSD128 PCM up to 32bit, 384 kHz |
| Supported sampling rates (Coaxial) | DSD up to DSD64 PCM up to 24-bit, 192 kHz |
| Frequency response | 20Hz-80kHz < 2.4 db 20Hz-20kHz < 0.1 db |
| Noise floor | 2.9µV on a 3.5mm jack 1µV on a 4.4mm jack |
| Output settings (3.5mm output, High gain) | |
| Powers | 2x 135mW @ 16Ω, THD+N < 1% 2x 125mW @ 32Ω, THD+N < 1% 2x 15mW @ 300Ω, THD+N < 1% |
| SNR | ≥ 117dB (A-wt) |
| THD+N | 0.0008% (1kHz/-6dB @ 32Ω) |
| Output impedance | 0.4Ω |
| Output settings (3.5mm output, Low gain) | |
| Powers | 2x 60mW @ 16Ω, THD+N < 1% 2x 30mW @ 32Ω, THD+N < 1% 2x 5mW @ 300Ω, THD+N < 1% |
| SNR | ≥ 111dB (A-wt) |
| THD+N | 0.001% (1kHz/-2dB @ 32Ω) |
| Output settings (4.4mm output, High gain) | |
| Powers | 2x 145mW @ 16Ω, THD+N < 1% 2x 280mW @ 32Ω, THD+N < 1% 2x 55mW @ 300Ω, THD+N < 1% |
| SNR | ≥ 129dB (A-wt) |
| THD+N | 0.0004% (1kHz/-8dB @ 32Ω) |
| Output impedance | 0.5Ω |
| Output settings (4.4mm output, Low gain) | |
| Powers | 2x 145mW @ 16Ω, THD+N < 1% 2x 125mW @ 32Ω, THD+N < 1% 2x 15mW @ 300Ω, THD+N < 1% |
| SNR | ≥ 126dB (A-wt) |
| THD+N | 0.0005% (1kHz/-8dB @ 32Ω) |
| General | |
| Supply voltage | 5V 2A |
| Dimensions | Around 68 x 68 x 12.9mm |
| Weight | Around 77.2g |
| Color | Pink |
| Package | 1x Snowsky Disc 1x USB-C to USB cable |
| Input | USB |
| Input | Micro SD |
| Input | Bluetooth |
| Output | Jack 4.4mm |
| Output | Jack 3.5mm |
| Output | Bluetooth |
| DAC / ADC Chip | CS43131 |
| Max sampling rate | DSD128 |
| Max sampling rate | 384kHz |
| Color | Pink |
