FOSI AUDIO DAP NEO Digital Audio Player DAP 16GB Silver
New
The FOSI AUDIO DAP NEO is a portable digital audio player designed for listening to your music library without relying on a streaming service. It features a Cirrus Logic CS43198 DAC and supports MP3, FLAC, WAV, APE, M4A and DSD files.
Reference : 22623
109,00 €tax incl.
90,83 € tax excl.
Fosi Audio DAP Neo Digital Audio Player DAP Bluetooth SBC CS43198 16GB Silver
Fosi Audio DAP NEO
The Fosi Audio DAP Neo is a portable digital audio player designed to listen to your music library without relying on a streaming service. It features a Cirrus Logic CS43198 DAC and supports MP3, FLAC, WAV, APE, M4A and DSD files. This version comes with a 16GB microSD card, and the player accepts cards with capacities of up to 256GB. For listening, it features an unbalanced 3.5mm headphone jack output and Bluetooth connectivity using the SBC codec.
Its 2.4-inch TFT LCD color screen, with a resolution of 320 × 240 pixels, displays music information, while its touch control wheel, side buttons and minimalist interface make navigation easy. Its all-metal enclosure, CNC-machined on a 5-axis machine, measures 97 × 47 × 10.6mm and has a maximum stated weight of 75g.
Compact and lightweight, the DAP Neo is designed for portable listening with wired or Bluetooth headphones, with a stated battery life of up to 12 hours. Its output power is specified at 129mW and its signal-to-noise ratio at 127dB.
Mises en situation du Fosi Audio DAP NEO
Fosi Audio DAP Neo: CS43198 DAC, Bluetooth and High-Resolution Audio File Playback
The Fosi Audio DAP Neo uses a Cirrus Logic CS43198 digital-to-analog converter to play MP3, FLAC, WAV, APE, M4A and DSD files. For wired listening, its 3.5mm headphone jack provides an unbalanced output. It also offers Bluetooth connectivity limited to the SBC codec. Storage relies exclusively on the included microSD card, which has a capacity of 64GB in this version; it can be expanded up to 256GB using a compatible card. The DAP Neo therefore lets you carry your personal music library with you, without requiring internal memory or streaming applications.
Fosi Audio DAP NEO : DAC CS43198, Bluetooth et lecture des fichiers audio haute résolution
Fosi Audio DAP Neo: 12-Hour Battery Life, Color Screen and Audio Player Controls
The DAP Neo offers up to 12 hours of playback on a single charge, depending on usage conditions. Its 2.4-inch TFT LCD color screen, with a resolution of 320 × 240 pixels, lets you browse tracks and display album information. Navigation is handled by a touch control wheel, accompanied by side buttons for accessing essential functions, including volume control, all within a deliberately minimalist interface. Its compact, all-metal chassis is CNC-machined, making it easy to carry around every day. The player comes with two screen protectors, a USB cable for charging and data transfer, and a user manual.
Fosi Audio DAP NEO : Autonomie de 12 heures, écran couleur et commandes du baladeur audio
Technical Specifications
Product typeDAP Digital Audio Player
Outputs3.5mm single-ended Jack
Bluetooth
DAC chipsCS43198
Battery life12h
DSD up to DSD256
InputsSD Card
Supported Bluetooth codecsSBC
Touchscreen
ScreenTFT LCD 2.4" (320×240px)
Supported audio formatsMP3, FLAC, WAV, APE, M4A, DSD
WiFi
SNR127dB
ConnectivityBluetooth
Storage16GB
ColorSilver
Dimensions97 × 47 × 10.6mm
Package contents1x Fosi Audio DAP Neo
2x Screen Protectors
1x USB-C Charging Cable
InputSD Card
OutputBluetooth
OutputJack 3.5mm
DAC / ADC ChipCS43198
Max sampling rateNC
ColorSilver
FOSI AUDIO DAP NEO Digital Audio Player DAP Bluetooth CS43198 16GB Silver
The FOSI AUDIO DAP NEO is a portable digital audio player designed for listening to your music library without relying on a streaming service. It...
