SHANLING Q2 Digital Audio Player DAP
The Shanling Q2 is a compact DAP equipped with four Cirrus Logic CS43131 DAC chips, capable of supporting PCM streams up to 768 kHz and DSD512. Its amplification delivers up to 425mW into 32Ω, while its 3.5mm and 4.4mm jack outputs ensure compatibility with most earphones and headphones.
By buying this product you get 27 loyalty points
Reference : 22390
279,00 €tax incl.
232,50 € tax excl.
SHANLING Q2 Digital Audio Player DAP Bluetooth 5.2 WiFi 4xCS43131 32bit 768kHz DSD512 Black
SHANLING Q2: Front view
With its aluminum and glass housing measuring 80 × 50 × 13.5 mm and weighing 83 g, the Q2 combines local playback, network streaming, bidirectional Bluetooth and use as a USB DAC or bit-perfect digital transport. Its MTouch system, its microSD slot compatible up to 2TB and its 1850mAh battery make it a player designed to centralize high-resolution audio playback in a portable format.
Shanling Q2: Digital conversion with four CS43131 chips
The Shanling Q2 features four Cirrus Logic CS43131 DAC chips, an architecture that allows it to support PCM streams up to 768kHz as well as DSD512. It reaches a signal-to-noise ratio of 130dB and a total harmonic distortion of 0.0005%, in order to preserve signal accuracy during digital-to-analog conversion.
SHANLING Q2: 4 CS41131 DAC chips
Shanling Q2: Compact format and headphone connectivity
The Q2 adopts a housing combining aluminum and glass, limited to 80 × 50 × 13.5 mm for a weight of 83g. Its 2.09-inch screen brings together the main playback information in a format suited to portable use. Despite these reduced dimensions, it features a 3.5mm jack output as well as a 4.4mm output, which broadens its compatibility with earphones and headphones equipped with a single-ended or balanced connection.
Shanling Q2: Output power and volume control
The amplification section develops up to 425mW into 32Ω, a power level able to drive most headphones and earphones on the market. Gain management adapts the output level to the different sensitivities of transducers, while the 100-step volume adjustment allows precise setting, particularly with sensitive earphones.
SHANLING Q2: In use
Shanling Q2: An architecture designed for audio
The Shanling Q2 is based on an Ingenic X2000 processor, combined with the internal MTouch System operating system. Developed specifically for audio uses, this environment prioritizes playback management and music functions in order to maintain an interface suited to library browsing and stream control.
Shanling Q2: Bidirectional Bluetooth 5.2
The bidirectional Bluetooth 5.2 connectivity allows the Q2 to transmit the signal to a compatible headphone or speaker, but also to receive streams from another source. Support for the LDAC, aptX HD, aptX, AAC and SBC codecs adapts the transmission to the associated equipment, with a quality depending on the selected codec.
SHANLING Q2: Bluetooth connectivity
SHANLING Q2: Wifi Airplay DLNA connectivity
Shanling Q2: Network access and streaming services
The Q2 natively features Tidal and supports Wi-Fi, AirPlay and DLNA connections. This connectivity allows access to online content or reception of music from various devices on the home network, in addition to the playback of locally stored files.
Shanling Q2: Memory expansion via microSD card
A microSD slot allows storage capacity to be expanded up to 2TB. This possibility increases the volume of high-resolution files accessible directly from the player, while retaining a compact format suited to transport.
SHANLING Q2: microSD slot
SHANLING Q2: Use as a DAC
Shanling Q2: Use as a USB DAC or digital transport
The bidirectional USB-C port allows the Q2 to be used as a USB DAC with a computer or a compatible device. It can also function as a bit-perfect digital transport, transmitting the stream without modification to an external DAC, which allows it to integrate into various audio configurations.
Shanling Q2: 1850mAh battery
The integrated 1850mAh battery offers a stated autonomy of up to 16.5 hours over Bluetooth and 13.5 hours with the 3.5mm jack output. This capacity allows several listening sessions to be considered without frequent charging, with autonomy varying according to the connection mode and output level used.
Technical specifications
Product typeDAP
Inputs1x USB-C
1x micro SD slot (2TB max)
Bluetooth
Wifi
Outputs1x Jack 3.5mm
1x Jack 4.4mm
1x USB-C
Bluetooth
DAC chips4x CS43131
Supported sampling ratesPCM 32bit 768kHz
DSD512
Screen2.09" (320x375px)
Supported audio formatsDSD (".iso", ".dsf", ".dff") / ISO / DXD / APE / FLAC / WAV / AIFF / ALF / DTS / MP3 / WMA / AAC / OGG / ALAC / MP2 / M4A / AC3 / M3U / M3U8 / OPUS
Operating systemMTouch System
ProcessorIngenic X2000
Bluetooth version5.2
Supported Bluetooth codecsLDAC, aptX HD, aptX, AAC, SBC
Battery1850 mAh
AutonomyJack 3.5mm : 13.5h
Jack 4.4mm : 12.5h
Bluetooth : 16.5h
3.5mm Jack specifications
Output powerLow gain: 30mW @ 32Ω
High gain: 120mW @ 32Ω
Frequency response20Hz-40kHz (1dB)
THD+N0.0005% @ 32Ω
Dynamic range125dB @ 32Ω
Channel separation65dB @ 32Ω
Signal-to-noise ratio (SNR)125dB @ 32Ω
Noise120dB @ 32Ω
Output impedance1.4Ω
4.4mm Jack specifications
Output powerLow gain: 120mW @ 32Ω
High gain: 425mW @ 32Ω
THD+N0.0006% @ 32Ω
Dynamic range130dB @ 32Ω
Channel separation110dB @ 32Ω
Signal-to-noise ratio (SNR)130dB @ 32Ω
Noise120dB @ 32Ω
Output impedance1.8Ω
Dimensions80 x 50 x 13.5mm
Weight83g
Package1x Shanling Q2
1x TPU protective case
1x USB-A to USB-C cable
InputMicro SD
InputWiFi
OutputBluetooth
OutputUSB
OutputJack 4.4mm
OutputJack 3.5mm
DAC / ADC ChipCS43131
Max sampling rate768kHz
Max sampling rateDSD512
The Shanling Q2 is a compact DAP equipped with four Cirrus Logic CS43131 DAC chips, capable of supporting PCM streams up to 768 kHz and DSD512. Its...
